I know you shoot single camera, but to make your life easier you might want to consider buying a used HV20 and cheap WalMart tripod to set up a wide safety cam in the back of the church. That way, if you have to move around a little to avoid unexpected groomsmen, gigantic flower arrangements, or pushy photographers you've got an angle to cut back to while you're getting re-adjusted.
If you look around, I'd bet you can get what you need for around $500.
The large print giveth, the small print taketh away.
-Ethan Cooper www.silver-media.net
