kino diva 400 went bang at DVinfo.net
Photon Management
Old January 7th, 2009, 12:31 PM   #1
Brand new, was buzzing from first time I used it then as I switched it off a loud bang came from within the ballast and it now won't fire up...any ideas?
Philip Bloom
Old January 7th, 2009, 04:20 PM   #2
Images: 18
Hi Phil..............
Burial, with full military honours, perhaps?
Slightly more practical, find the receipt and "Return To Sender" post haste.
CS
Old January 7th, 2009, 04:39 PM   #3
Warranty repair of defective Ballast. Unless for some reason you plugged in a US version in a 220Volt socket. Then they might argue over the repair.
Old January 7th, 2009, 04:50 PM   #4
Phil:
Long shot, the Diva is sold in 120V only versions and dual voltage versions (240/120V). I have never used the dual voltage version and don't know if it has a switch for 240V operation but if it does have a voltage switch or setting and you had it on 120V and plugged into 240V, yes, I agree with Chris, that would definitely cause a bang.
Check it out and let us know.
Dan
Old January 7th, 2009, 05:23 PM   #5
Images: 18
Hi Dan.............
The 400 Universal has an auto voltage sensing power supply, no switch to forget (or so says the Kino web site).
So I guess, unless it was a 120 Volt unit (who's fault would that be? Could be interesting) it's just plain faulty out of the box.
CS
Old January 7th, 2009, 05:41 PM   #6
Smoke
Obviously, you let the smoke out.
Let me explain: all electronic circuits "feed" on smoke. When you purchase a new electronic device, it comes with a certain amount of smoke inside to feed all the hungry little bits. When you plug in the device, all you are doing is warming up the smoke to make it more palatable to the electronic doohickeys inside your device. When the smoke has been adequately heated, the electronic parts begin to do their part to make the device work, in the case of your light, they create light by shining it out of their bums.
Sometimes, if one isn't careful OR if the smoke containing vessels are somehow ruptured, the smoke is let out and the device ceases to work. You'll know if this is in fact the case as you will see the smoke come out of your device.
Hope you got a chuckle. Good luck with the repair/replacement.
Old January 7th, 2009, 05:44 PM   #7
Images: 18
Shaun...........
Speaking of smoking................
CS
Old January 7th, 2009, 07:24 PM   #8
Wow. That's all I can say. Wow.
You are giving away the secrets. Now the rabid elves are going to descend on you and take you away to the gathering place for a ritual stoning.
Dan
Old January 7th, 2009, 07:59 PM   #9
I think CS was intimating earlier that I was already ston... never mind.
Old January 8th, 2009, 10:36 AM   #10
Yes, I got that, I was just trying to get into the same spirit of weirdness that your post had... ;-)
D
Old January 9th, 2009, 02:24 AM   #11
yeah it's dual voltage and it's going to be shipped back to B and H for repair. What a pain!
Philip Bloom
Old January 9th, 2009, 10:17 AM   #12
There are a couple of places which do warranty repair for Kino. At least one in NY and of course back at Headquarters on CA. I would just ask for a new replacement one if it did this on the first shoot. Also did they say how long it would take to get this one back. This is one reason it is sometime nice to buy locally as they could probably get you a loaner. Good Luck
Daniel Epstein is offline   Reply
