View Single Post
Old January 12th, 2009, 08:54 AM   #5
Jeff Harper
Do not give up on mini-Dv. The rumours of its demise are greatly exagerated.
Check into the Canon HV-30 Hi Def cameras. At less than $600 each they are exceptionally nice and for the money you cannot get a better image.
If you have more money, the FX7 at around $1995 offers better low light capability.
If your church is relatively dark, consider buying used SD cameras such as the Sony PD-150 or PD-170, or if you don't need pro audio hookup look at used Sony VX2100s.
The files form hard disc camcorders do not always do well in Vegas. With mini-DV you are assured of a great editing experience. If you are making these purchases on behalf of the church, or if they are going on your recommendation, I would certainly stick with Mini-DV as you will have no issues in post.
If you have much more money, look at the Sony FX1000 for $3200 which will give you great performance in HD and good low-light performance.
Few professional videographers would recommend you go with a hard disc camcorder at your church.
