Weird Encore Problem
I have a project in Encore CS3. In it, I have a menu, sub menu with chapters and several clips exported from PP that has chapter marks (CS3)
In the flowchart on Encore I go to link a submenu chapter to a chapter point in a clip. The problem there are no chapter points from any of the clips, just of the two menus. When I open the clips on Encore's Timeline, the chapter points are displayed. Any of you have had this problem in the past? What did u do? Thank you. |
Chapter points are to be linked to menu or sum-menu buttons. The flowchart is used to link timelines to the buttons. Open your menues on the left and the flow chart and just link with the pick-whip.
Easiest to make each separate video section a timeline and link to them that way. In the timeline you can link the chapter point to the button, in order to get the image or to animate the buttons. Anyway it works for me and is easy that way. Just did it yesterday. Mike |
Mike |
Thanks Mike for your input. The video was mpeg 2. I was messing around with it today and when i re-imported it, the chapter points came up. So its all good now.
Thanks again. |
