Premiere Pro CS4 4.0.1 Update with OMF and Final Cut Project import
Cool news. We knew OMF support was coming. Now it's here.
From Adobe's website: "The Adobe® Premiere® Pro CS4 4.0.1 update adds support for AAF import/export, Apple Final Cut Pro XML project import, and OMF export, along with numerous other stability and quality improvements. The update is recommended for all Adobe Premiere Pro CS4 users." The update download link: PC: Adobe - Premiere Pro : For Windows : Adobe Premiere Pro CS4 4.0.1 update MAC: Adobe - Premiere Pro : For Macintosh : Adobe Premiere Pro CS4 4.0.1 update |
I`m surprised FCP import really works (testing now), and surprisingly well too. I didn`t expect niceties like importing blending modes, motion or transitions.
Now to test AAF/OMF functionality. That is SORELY needed in Premiere. Anything more than simple videos needs audio sweetening. |
When I heard about the final cut pro import, I was super excited, I have a PC at home and FCP at school, so this would save a lot of time. However, when I tried to import footage captured in final cut (the footage still doesn't have an extension e.g. mov) so it failed to import. Also, when I manually add the extension it does not work either.
Perhaps I am miss understanding, but does this mean that I can capture footage in Final Cut Pro, then import that footage into premiere or do you have to export the whole project? How did you do it Jiri? |
I`ve just tried importing ProRes project so far. It works flawless, except Prores footage plays kind of sluggish. But I understand this option more as a means to importing into After effects, and I don`t need realtime there.
I will experiment some more and share the results. |
I too want to find out more about this. I am a Premiere guy, and this may mean the ability for me to freelance edit weddings for a videographer who wants to tweak stuff after I edit in FCP.
I don't really need the option to import FROM FCP. Rather, I need the option to be able to export TO FCP from Premiere CS4. Can anyone recommend a way to do this now that these options have been added to CS4? |
You can only do this via EDL, but that works for simple cuts-only sequences with 1 video track.
So the only export available right now is for audio only? (besides EDL of course).
