PPro 1.5 EDL Limited- Sequence Import Impossible
HI there,
I'm using PPro 1.5. I tried to import a sequence from one project into another using Export EDL. The only problem is that the options are limited as I had 5 video tracks and 3 audio tracks occupied but when exporting EDL's they ask you to choose only I video track and 2 audio tracks. What I would like to know is: 1) Does EDL exporting improve in PPro 2.0? 2) Is there another better way to import a sequence from a different project? (other than selecting everything on the sequence and cut & pasting) thanks. |
Hi Melanie, welcome to DV Info!
To import a project into another project go to File > Import and choose the project you wish to import. |
1) yes
2) u can directly import a project into another project, you will retain full sequence edit. You may do this also if you wish to change project settings. |
well it only allows you to import 1 Video track and 3 audio tracks- is there another way to export with ALL my video and Audio tracks?
How about PPRO transfer into Avid?
THanks Chris. Your right and it works perfectly. But how about if I want to import a project exactly how it is from Premiere Pro into Avid or vice versa?
