Z1E and Adobe PP 2.0
Hello! First time poster so I hope I'm not doing anything wrong!
I bought a Sony HVR-Z1E camera last week, planning on shooting several documentaries in HD. I am using Sony HDV DigitalMaster 63 mins tapes. When filming the Rec format is HDV 1080i (PAL). Now comes the tricky bit that I want to get right. Editing will be done on a high spec PC and I'll be using the i.Link cable (firewire) to capture the footage into Adobe Premiere Pro 2.0 : but what would be the correct Project Settings and Capture Settings? Currently I am doing this: Capture Format: HDV Editing Mode: HDV 1080i Timebase is set to 25.00 fps and this I can't change. It does however, seem to set the Project Settings General Video frame size to 1140 1080 (16:9) and this is something that confuses me. When exporting I run into some problems and am not sure what to do... So basically what I'm asking is: what settings would you recommend and can you give me any tips on making sure I get everything right? Many thanks in advance and any reply is appreciated! :) |
I think you mean 1440x1080, not 1140, yes? That's what it's supposed to be. In PAL-land, 25fps is the correct frame rate. So stick to the presets and you should be fine. What kind of export problems are you having? Mods: Move this to Premiere Forum? |
