New Beach Tek DXA-10 stereo
Fed Ex just brought me a Beach Tek DXA-10.
Same size as the other units but it doesn't attach to the camera. It comes with a belt clip and could be camera mounted using an accesory bracket. My first impressions are, what a well thought out little whizbang. The biggie with the DXA-10 is that it's made for the consumer mini disk , flash and hard drive recorders. It has XLR inputs with separately switchable 48volt phantom and 2 stages of gain (30 and 60 db) The outputs are 2 RCA's at a max output of +18 db or a mic 1/8 stereo mini output at -37db. With this setup you could feed a camera or other high level recorder using line input or a consumer camera or recorder at mic level through a simple 1/8" mini stereo cable. This has most of the bases covered, it's light and it's inexpensive. it wouled also be a natural for the Edirol unit. For pictures look here 2 balanced XLR inputs 2 line level RCA outputs mic level stereo mini jack output (3.5mm or 1/8") Dual low noise preamps with +/-15 volt rails for wide dynamic range Hi/Low gain setting for condenser and dynamic type mics (30 and 60db) Dual switchable 48volt phantom 9 volt battery compartment with LED battery indicator removeable belt clip Gain switchable: Hi (60dB) Low (30dB) Freq response 20-20Khz, -1dB THD+N > .03% @1khz 9lo gain +4dBu output Signal to noise 66@1khz +4dBu Max output+18dBu (RCA) -37dBu (mini) Phantom Dual rtegulated 48 volt (current to 14ma) battery 9 volt good for 4 yours (no phantom) Current draw120ma (no phantom) Case is powder coated aluminum 5.25"Lx3.5"Wx1.25"h Wt 14 oz |
Bryan does this work well with your Winter mod? What about the lack of limiters? If i remeber correctly you said before that it was very hard to clip the input stage with the mod to your VX.
I haven't got that far yet. I just received the unit about an 2 hours ago and i'm not to mobile yet. I had knee replacement surgurey about 7 weeks ago and my right knee is still bone on bone. i'll get to it ;-)
Out of the box, the size and configuration really impressed me, especially the outputs (mini and RCA and at 2 different levels) |
No problem. Take your time. I'm looking forward to your results. I can remember 8th grade health class they showed us a knee replacement video or some knee related surgery and to this day those images haunt me. I think it was watching the knee just split open under the knife.
I should've setup my camera and taped it. the OR looked more like a shop with all the hand and power tools. The Beas knees on video.
Matt why don't you emsail me with some test suggestions bbeasleighat rogersdotcom. |
Brian,
How much is it? I don't see it on bh yet. No limiters, I assume. I'm kinda vascilating between the mix pre and the 302 at this point. feel better. bruce yarock |
It's supposed to sell for the same price as the DXA-8. It hasn't hit the stores yet, the unit was shipped directly from the factory (in Canada not offshore)
