Beachtek Dial Noise
I just recently purchased a used Beachtek DXA-4 off of eBay for my VX2000.
I notice that whenever I change volume dials, the audio feed in my camera actually picks up the physical sound of dial being changed. I know the sound isn't recorded from my microphone, because I hear it when there are no mics plugged in at all. It does the same thing when I hooked the Beachtek box up to my backup trv17 camera. Is this normal for these units, or did I get a defective DXA-4? |
I have one, and it is normal. In fact the instructions that came with it mentioned that the knobs are for presetting levels and not intended to be changed as you shoot. In other words, it isn't a mixer that you can actively operate.
Unfortunately that's just the way it is... |
Thanks Boyd, well at least I know it isn't broken.
On a similar subject, I have another question. If recording with just one microphone, is it generally recommended to keep the audio dial at the highest level of 10? I wasn't 100% sure because there are no visual meters, and I don’t trust my own hearing. |
Use the level meters on your VX-2000 (push the audio level button). To play it safe, make sure the level never goes higher than -6dB (some extreme peaks, like a gun shot might hit -3dB).
From the DXA-4 manual Quote:
You're kidding right?
I have two "one of a kind" XLR shorties with built in variable audio pads. I can dial them up or down as needed. If I can have two custom made variable audio pad cables made, why can't Beachtek do the same?
Only Beachtek can answer that question.... http://www.beachtek.com
