Wireless Mic
I have been using two AudioTechnica U100s for years, with mixed results. The TX takes one nine volt battery and the RX takes TWO nine volt batteries. I have two of these units, so every time I do a battery swap it's costing me $12, and I'm sick of it.
I have used a Sennheiser G3 a few times with good results. about 1/4 the size of the U100, two AA's, and decent reception. Anything else in this pricerange that I'm missing? |
Re: Wireless Mic
Before you replace what you already have, have you ever thought about using good rechargeable 9v batteries for your wireless units? I've been using these for many years now, and they work better than alkaline 9v:
http://www.bhphotovideo.com/c/product/627506-REG/iPower_IP9V520_9V_Li_Polymer_520mAh_Battery.html After a couple of gigs it will pay for itself! |
Re: Wireless Mic
The Sony UWP-V1 is a less expensive contender but I've never used them myself.
I've been using two Sennheiser EW112 G3 systems since they first came out and I'm really happy with them in terms of wireless reception, sound quality, and battery life. Rock solid performers. I use them with both Alkaline and NiMH rechargeable batteries. Warren makes a good point, if you can use rechargeable batteries, you can save in the long run. |
Re: Wireless Mic
1 Attachment(s)
Here is the recording - direct into the Panasonic HPX500 Sony UWP-V6 Wireless Lavalier Microphone 200' distance - YouTube Also, if batteries are a big concern, the new Sennheiser G3 units now have charging contacts. This may be a factor if you're using the system often. I'm also kicking around a new lightweight UHF wireless from Samson. Samson AirLine Micro Camera - Wireless System - DVeStore The only real bummer is that it is single channel (not frequency agile with 1600+ selectable frequencies like the G3). Basically when you purchase you pick N1 - N6. The transmitter and receiver are the size of a box of a matches! Dang these things are light too - even with the built-in lithium ion batteries - and at $299, you could get two sets for the price of G3. |
Re: Wireless Mic
On a recent range test in the UK by the Institute of Broadcast Sound - surprisingly the G3 came out best, beating even far more expensive kit from Lectro, Audio Ltd. and Zaxcom (and even the more expensive Sennheiser kit).
Re: Wireless Mic
Also, if the test was in the UK, was the "more expensive Sennheiser kit" a Sennheiser 2000 series or 3000/5000 series? |
Re: Wireless Mic
Re: Wireless Mic
There is a DC IN USB port on the bottom. The manual says that you can use a computer to charge the unit or a cell phone charger. It does say that AC power using the included charger would charge faster than a computer. I'm guessing that you could also use one of these optional external battery packs out in the field If I plug the included AC charger into the Xmitter while it is on, it does indeed power off the unit. And ouch, make sure you headphones are off - you get a blast of static when the Receiver loses the Xmitter. No pilot tone argghhh. Note that the Samson wireless does include both miniplug cable and miniplug to XLR, which tells me that they may be aiming these at higher level cameras than just the consumer models. I'm not totally sold on 'em for a pro project other than the size may be a crucial factor for certain shoots.The Sony or the Sennheiser still get my vote. |
Re: Wireless Mic
I bought one, it'll be here tomorrow. More details then.
Re: Wireless Mic
The more expensive Sennheiser was an SK 2012 I think. |
Re: Wireless Mic
Here in US we have the 2000 series pumping out 100mW. It's kind of hidden in the menu, but if you hold down the Up arrow when selecting RF Power it goes up another level above "High" to "Maximum". Maybe the settings on the Transmitter were set to "Low"? Because I just did a test today with the SK2000XP Transmitter with the "Maximum setting" side by side with the SK100 G3 Transmitter. I can guarantee you that the Sennheiser US model of the 2000 series easily outperforms G3 in terms of range. Quote:
Re: Wireless Mic
The UK works to ISO specs and the maximum e.r.p.is 50mW for a pocket transmitter and the spectrum mask is a lot narrower than the one for the USA. All the mics. in the test were to the ISO spec. and the G3 was actually the least powerful at only 30mW conducted power. But the test also included blocking of buildings and metal buildings inside a scenery store - this is where they all fell over and the G3 lasted a bit longer than the others. |
Re: Wireless Mic
Of course, the true test is sound quality and distance, neither of which I can attest to at this point. More soon. |
Re: Wireless Mic
Mike ~
What's your review of the Sampson that you've bought? |
Re: Wireless Mic
The thing is a total piece of junk, it won't hold a signal longer than about 30 seconds or farther than about 10 feet. Suffice to say I would not repeat.
