Problem with Sennheiser G2 lav
I rented a Sennheiser wirelless lav and I have this problem with it - when I touch the cord of the Sennheiser lav, I can hear crackling noise in the sound. Is there a way how to fix it? Its impossible to put the mic on somebody without touching the cord. If the person moves and the cord moves too, the noise appears. The cord cant be changed, because its part of the mic.
Re: Problem with Sennheiser G2 lav
The cable is likely broken. If the damage is down by the plug (the usual stress point), the connector can be replaced, but this requires some electronic/soldering skills. Even a non-locking 3.5mm TRS plug can be used in a pinch.
If the cable is broken close to, or at the mic element, that is usually not repairable and requires a new mic assembly. (mic/cable/plug) |
As Rick said, you have a bum Lavalier. Hope you can get a refund on the rental.
For others who come along this thread searching with the same problem: if it's a Sennheiser Lav, they have a refurb program where you send them the bad one and they send one they've repaired. It's about half the price of a new one. |
ONLY to be used in a dire emergency and then changed for a locking one at the earliest opportunity. |
Many thanks! ~TRW |
The website for Support has changed. THere use to be a form you could fill out and a schedule of flat rate repairs. Looks like there's a gatekeeper page now where you create a service request and go from there.... https://service.sennheiserusa.com
Let us know if the program is still there. |
If you're referring to an ME2 (or ME4) .. even half price (however they calculate that.. I know the street price is around $130), is it worth getting an awful sounding mic fixed? I'd get an OST for around $90 and be done with it
Thanks for the hint about the OST's, Rick...I just might go that route! Judging from your comment, is it safe to say that their connectors are built better than the Sennis? Nice price point, too!
~TW |
Yes, OST uses a (Tec-Nec I think) locking brass plug, soldered on by OST. The Sennheiser ME series mics use a cheapo molded-on plug which is far more prone to breakage. Not only is the OST plug much better quality, the locking ring retracts enough to use in a conventional (non-locking) 3.5mm jack. Can't do that with the Sennheiser, the locking ring prevents full insertion.
BTW, the lowest street price I've seen on the ME2 is currently $139 USD.. Sennheiser's list price is $189.. do the math. |
Hi, Rick! Since you were responding to my question, is it safe to say you meant Senni, Not Sony? Incidentally, and a bit OT, you're not related to Steve Reineke (big time "Pops" orchestra conductor), are you? I noticed you're in NYC and I he's there too! He used to be the conductor for the Long Beach Pops out here in CA and we miss him!
~TW |
"is it safe to say you meant Senni, Not Sony?"
- Yes Terry, thanks for catching that, I will correct it so no one else is confused. I have cousin Steve, but he's an attorney, though many in my family were/are musicians, including myself. |
If he rented it, then buying a mic is not an option, is it. Getting at least a partial refund is! If the mic was faulty, then he also has the evidence in the recording.
I also wonder if perhaps the hire company just accidentally included a dodgy mic? However - noise from the cable is a bit more complex. Two kinds, electrical and mechanical. Some cables seem to age badly, and some brand new ones of cheaper makes (it could have been a non-sennheiser mic on a genuine Sennheiser radio pack) have microphonic cables. The friction noises go up the cable sheath and are mechanically linked to the capsule, which produces a quite distinct sound. Broken conductors either cut the audio, intermittently or totally, or crackle and bang. Again, an electrical fault is a very specific noise. If we could hear it, we could tell - but it's too late now. |
