October 9th, 2017, 09:56 AM | #16 |
Re: Lectrosonics transmitter/receiver
Switching from the Sanken to a 'better' mic would be negligible at best. An external preamp would help more if your plugging it direct to cam. An MixPre or MM1 for instance.
BTW, the Zaxcom RS200 Rx is pretty compact @ 1.0″ x 3.5″ x 3.5″. The RS900 Rx that I've used was plenty small enough for a bag, about 5"x3" (or 4)" as I recall. |
October 9th, 2017, 10:16 AM | #17 |
Thanks. I guess I'll stick with my Sankens but I can't add a preamp to my set up (I mean I can but don't want to, willing to sacrifice the quality).
October 9th, 2017, 02:52 PM | #18 | |
The weak link in just about any record-to-camera workflow is the mic preamps in the camera. Any camera. None of the in-camera micpres are as good as the bottom end SD mixers. And you can get a used MixPre-D for very little these days, and it's designed for your stated workflow (camera as recorder). But if you don't want it, you don't want it. You know your situation better than anyone. |
October 9th, 2017, 03:54 PM | #19 | |
Thanks |
October 9th, 2017, 04:40 PM | #20 |
One more question is it possible to use two transmitters but just one receiver?
October 9th, 2017, 07:57 PM | #21 | |
If you have any questions about the LR/LTs I'd be happy to answer them. |
October 9th, 2017, 08:04 PM | #22 |
October 10th, 2017, 09:20 AM | #23 |
OTOH, it's common to use multiple receivers with one transmitter. i,e; hopping audio to more than one camera, but not the other way around with single channel wireless systems.
... It should be noted though, the 'one Tx, multiple Rx' scenario will NOT work with the new WiFi band GHz systems, like the Sennheiser AVX, RODE filmmaker, AT System 10, ect. |
October 11th, 2017, 05:31 AM | #24 |
Zaxcom makes a miniature transmitter, the ZMT3.
Zaxcom ZMT3 miniature transmitter announced: get two, you might lose one - Newsshooter Also, every one should watch this (BEST ADVERT EVER! Well, for wireless at least):
http://IronFilm.co.nz/Sound/ (Location Sound Recordist based in New Zealand) http://www.YouTube.com/c/SoundSpeeding |
October 11th, 2017, 05:41 AM | #25 |
Cool unit, but best avert ever? Not for me, I could not get through it.
October 11th, 2017, 06:56 AM | #26 |
Well most adverts for pro wireless are pretty dry affairs!
This one has some humor to it :-D
October 12th, 2017, 06:43 PM | #27 | |
October 12th, 2017, 08:28 PM | #28 | |
October 13th, 2017, 08:36 AM | #29 | |
Lectrosonics Introduces the SMWB and SMDWB Wideband Transmitters SRb Series SRc Dual Channel Slot Mount ENG Receiver All of these require external power but there are battery options available. Sony makes a dual channel receiver for $700 that works with their inexpensive transmitter. https://www.bhphotovideo.com/c/produ..._receiver.html https://www.bhphotovideo.com/c/searc...e&N=4232860122 Sony also makes some higher end dual channel receivers and transmitters but are slot in units that can be adapted for stand alone use. And here's a set with two tx: https://www.bhphotovideo.com/c/produ...iver_with.html |
October 14th, 2017, 12:59 PM | #30 | |
