Connecting the NTG2 to a 1/8 jack
Hey I have the NTG2 rode shotgun mic on order, but I need to know the correct way to hook it up to my camcorder's 1/8 input. The guy ordered me in a basic 1/8 to XLR, but I've heard this isn't enough to totally balance it, what is the most popular product used to balance xlr to 1/8? Also I plan to use a mixer in the future, I'm going to be buying a behringer UB1204, is this acceptable for use with video, and how would I go about hooking it up? thanks
Luke |
The UB1204 mixer would work fine for video but it requires mains power which limits where you'll be able to use it - a battery powered unit would be much more flexible. While it's considerably more expensive than the Behringer but something like a Sound Devices MixPre or other field/ENG mixer would be a better investment in the long run. |
To continue the advice, even after getting a mixer, you'll still use an adapter like the BeachTek to make the hookup to a camera that has only an 1/8-inch stereo mini input.
The chain would then be Mics (and other devices) hooked to the mixer, Mixer to BeachTek (set for Line-level signals), BeachTek to Camera. The least expensive balanced adapter is made by Shure, but it must be physically secured, only has one input and no additional controls. A BeachTek, Studio1 or Sign Video type adapter box solves these problems. The BeachTek DXA-6 can also provide phantom power. An unbalanced adapter cable will work if it's wired properly, although as mentioned you lose the benefits of a balanced connection. Do a search here, there's several threads that list all these parts. |
Hey thanks very much, that cleared up a lot of things for me. Is this thr shure adapter you speak of?
http://www.shure.com/accessories/a96f.asp The place I'm ordering from also ordered me a digiflex 1/8 to xlr, http://www.digiflexcables.com/digifl..._en/video.html The cable is on pg 11 of their price catalogue , altho there is a special cable on pg 14, not sure if it would be good. their price catalogue http://www.digiflexcables.com/digifl...etail_1104.pdf they said it was only like $8 or something. I'm guessing this would be unbalanced, not sure tho. I can always refuse the part if i want. Luke |
A "regular" cable won't work. Trew audio in Nashville has a cable that will work. Tell them you want a mono female XLR with pin two to tip and ring and ground to sleeve. It's a balanced mono mic to unbalanced stereo input cable. It'll feed the mic to both channels. I talk about it in my book. For short runs it will be fine. Regards, Ty Ford |
