Frame to frame at DVinfo.net
Adobe Creative Suite
Old August 31st, 2004, 04:11 AM   #1
Frame to frame
Hello
In Premiere pro 1.5 when putting a paper clip in way frame with
zoom to the maximum, I observe that the current-time indicator
(vertical red line) does not cross frames one by one.
Somebody has observed this? How it is corrected? It is normal?
Thanks.
Eloy Varela is offline   Reply With Quote
Old August 31st, 2004, 05:28 AM   #2
Hi Eloy,
I'm sorry but I do not understand what you mean.
Can you word your message a little bit better?
What do you mean by paper clip?
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline   Reply With Quote
Old August 31st, 2004, 06:09 AM   #3
I really feel it, I use a bad system of translation. I have an image
that could explain this, but do not know like sending it.
Old August 31st, 2004, 07:20 AM   #4
hello,
when the Timeline is frame mode, with the zoom
to maximum, the current-time indicator frames does not jump one by one. If indicator it is in frame, if we go to following frame the indicator would have to be located clearly in this frame and
sometimes the current-time indicator is placed between two frames.
Thank for its effort to understand me, and hope that it is a
problem of configuration and not of Premiere.
Old August 31st, 2004, 12:21 PM   #5
I inderstand.
You want each little picture icon on the timeline to represent one frame like it used to in Premiere 6.5.
I want this also. But it will not happen.
Adobe did not make this possible in Premiere Pro. I put in a feature request for it. Maybe they will add it.
Steven Gotz is offline   Reply With Quote
Old August 31st, 2004, 12:59 PM   #6
Hello,
I think I understand now...
I would say that this is a bug.
As it says in the help file, "The number of thumbnail frames corresponds to the time units displayed in the timeline ruler".
Since you are zoomed fully (1 frame), the thumbnails should correspond to the timeline, which as you have found out it does not.
Ed Smith
Hampshire, UK
Old August 31st, 2004, 01:16 PM   #7
The problem is that you can't zoom in to one frame. The lowest zoom level is slightly more than that. A little over one frame.
Most people do not use the timeline to edit frame by frame. They use the source or monitor window. Or sometimes the trim window.
Therefore, the ability to see a single frame on the timeline somehow got lost when the features were determined for Premiere Pro.
Old August 31st, 2004, 01:41 PM   #8
P6.5 zooms down to 5 frames, the same as PP, and yet is able to show 1 thumbnail (size) per frame. The thumbnail frame size seems slightly larger in PP. It gets worse if you make the track bigger, as you'll get less thumbnails.
Ed Smith
Hampshire, UK
Old August 31st, 2004, 01:48 PM   #9
Correct. If the track could get a slightly bit smaller, it would show a single frame. Or if the zoom was a little tighter.
Old August 31st, 2004, 01:55 PM   #10
Agreed ;)
Eloy,
I hope this answered your question
Ed Smith
Hampshire, UK
Old August 31st, 2004, 03:07 PM   #11
Ed, Steven,
Thank you very much by his detailed explanations. My doubts have been perfectly clarified.That is very kind of you.
Eloy.
Old August 31st, 2004, 03:27 PM   #12
Please remember to put in a feature request here:
http://www.adobe.com/support/feature.html
It is the only way we will get what we want.
Steven Gotz
http://www.stevengotz.com
Old August 31st, 2004, 04:15 PM   #13
Ok, Steven
