I/O error at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
Avid Editing Family
All flavors of Media Composer, Symphony and more.
Old November 4th, 2009, 05:38 AM   #1
I/O error
Hello,
I have some serious pc problems. I was trimming the sequence in the timeline, and suddenly (probably during an autosave) the program was frozen. These are the error messages I received after a while:
Exception: Disk-IO-Error, filename F:\AvidMediaFiles\MXF\1\msmFMID.pmr
Exception: Sys-Error, status: 1117: The request could not be performed because of an I\O device error
There must be something wrong with my internal F-drive on which all media is to be found. Reading this drive with other software also gives errors.
According to the Device Manager the disk is working properly.
Would you have some advise?
Rob
Rob deJong is offline   Reply With Quote
Old November 5th, 2009, 01:18 PM   #2
You've tried exiting and rebooting right?
If that doesn't work, it sounds like an Avid database problem, which usually isn't that big a deal. But I would suggest also posting on the Avid's user forum for something like this.
Forums - Avid Community
The solution I'd suggest includes deleting some database files, but I don't feel comfortable getting into the details b/c I might be wrong and don't want to make things worse. No matter what you do, just be sure to make a copy of any files you delete, and you should be okay.
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0
Old November 17th, 2009, 08:13 AM   #3
Thanks for your recommendations. Now, the F drive died!! So That was the problem. Lost a few days of work, but alive and kicking.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Avid Editing Family
