Possibly a dumb question at DVinfo.net
Canon EOS Full Frame for HD
Old July 27th, 2009, 04:04 PM   #1
I thought I could run a cord from my Zoom 4n to my Mark II for audio and that would overide the on board audio, but all I get is static. Can someone tell me if what I am trying to do supposed to work? I was able to get my wireless to work, so it should be possible. Thanks for any help.
Jerry
Bruce G. Cleveland is offline   Reply With Quote
Old July 27th, 2009, 11:54 PM   #2
My guess is that the static is the camera recording its own internal noise because it cranked up the gain on an empty signal. Are you sure the H4n was sending audio?
Old July 28th, 2009, 04:29 AM   #3
So what I am trying to do should work then? Maybe I have a cable that is not right. It is a stereo cable on both ends. Do I need to configure anything on the zoom or camera?
Bruce
Old July 28th, 2009, 04:43 AM   #4
If H4n has "LINE OUT" then 5D MKII can not accept it directly as it has "MIC IN"...
Toenis Liivamaegi is offline   Reply With Quote
Old July 28th, 2009, 06:19 AM   #5
4n does not appear to have a mic out, only line out. Thanks.
Bruce
Old July 28th, 2009, 06:22 AM   #6
Bruce,
You need to PAD the output from the recorder, I had a special cable made for my recorder.
Dan
Old July 28th, 2009, 07:54 AM   #7
Thanks Dan. Can you tell me where I can get such a cable? I feel like I know so much about this stuff, yet no nothing. Thanks again for any help.
Bruce
Old July 30th, 2009, 03:47 PM   #8
Wow my post got buried. Hey this is for Dan Chung. You were saying you had a special audio cable made for your zoom recorder and 5d camera. Can you tell me where you got that? Thanks.
Bruce Cleveland
Old August 1st, 2009, 08:05 PM   #9
anyone have an answer to this? Someone must know.
Bruce
Old August 1st, 2009, 09:58 PM   #10
Bruce,
Sorry, you are right , I missed this. You need to connect the line out of the H4n to a cable that has an in line attenuator. You should be able to get one made, basically you will have XLR sized barrel in line at some point. You could use one of these Shure - A15AS In-line Switchable Attenuator with XLR to jack cables but you would be better off with a custom solution.
In the UK I use Pinknoise systems for this stuff, not sure about the USA.
Dan
Old August 2nd, 2009, 05:05 AM   #11
Thanks Dan. I appreciate it.
Bruce
