T2i Slowmo: Fast way to get 60p to 24p? at DVinfo.net
Canon EOS Crop Sensor for HD
Old August 25th, 2010, 12:39 AM   #1
I have lots of 60fps video that I want to slow down to 24 (40%) in premiere. Easy enough to change the speed on a single clip. But what if I have 40? Is there a simple way I can do all of them at once?
Havn't been able to figure that out yet.
Stephen Henderson is offline   Reply With Quote
Old August 25th, 2010, 01:17 AM   #2
I use Cinema Tools to do the slow motion conforming, but if you don't have that, I believe you can right click the clip you want to change the speed of in PP, then there should be an option in the drop down menu that allows you to alter the speed. Let me know.
Brian Amodeo is offline   Reply With Quote
Old August 27th, 2010, 03:50 PM   #3
Thanks, yes changing a single clip is easy enough, I'm trying to change 30 individual clips in such a way that all of them stretch out, not stay the same length of seconds on the time line.
Edit:
OK, sorry, I figured it out:
Select the tracks adjust speed and check the box that says Ripple Edit,shifting trailing clips.
Old August 27th, 2010, 06:14 PM   #4
Glad to hear everything worked out ok.
Old September 5th, 2010, 07:49 PM   #5
in CS5, right click on the clip and interpret it as 23.976
also find an app called qtChange from video took shed. it will let you change the FPS of an entire folder of clips, change TC, set clip TC to Tod, ect. a REALLY great app, and its shareware
Steve Oakley DP • Audio Mixer • Editor • Colorist
http://stevenoakley.com
Steve Oakley is offline   Reply
