Is there a trick with this stupid eyecup!! at DVinfo.net
Old January 23rd, 2004, 01:34 PM   #1
I wear glasses and would like to use the bigger eyecup but i cant seem to get the damn thing off!! I dont want to ruin any hting i have been sitting here for 20min trying to figure this damn thing out. Can some give me an easier way to get this stupid thing off
Joel Ruggiero is offline   Reply With Quote
Old January 23rd, 2004, 02:02 PM   #2
Old Boot
Gently Does It Joel!!
Yeah .. same here . . I gently peeled it away from one corner. You need to get to the point where the small rubber is at a corner and just gentle "peel" it off one corner. The rest should just fall away. Make sure you have the eyepiece of the cammie in the locked horizontal position. I've made it happen, but it did worry me when I did it. Be careful . .
Grazie
Old January 23rd, 2004, 03:00 PM   #3
thanks i got it now
Old January 24th, 2004, 03:22 PM   #4
its pretty impossible do damage the eyecups..im pretty violent with them...
Lyndon Golanowski is offline   Reply
