GL2 tape playback problem. at DVinfo.net
Old February 5th, 2004, 07:48 PM   #1
911, need advice fast.
Ok, here´s the scoop. I´m in Patagonia for 5 months making flyfishing videos throughout chile and argentina. I´ve collected some outstanding video but my gl2 isn´t functioning right.
On my latest recorded tapes I´ve noticed that when there played back for review on the gl2 there are grey bars horizontally stacked over the recorded footage. three tapes are having similar problems. some of the tapes have horizontal bars of previous footage over the current playing footage.
The last time my gl2 recorded correctly was two days previous in a rain storm. the footage all through the rain storm came out perfect but the last time I used it all my tapes came out disstorted. the camera body was kept very dry with a kata rain cover but I think moisture might be the problem.
anyways, I need to know if someone has had a similar problem? what the problem might be? and if the footage is lost or can it be saved? I´m in a real pinch here. the expedition needs to push on and we can´t do it without a camera. Please respond with any sollutions as soon as possible.
can someone save my ass?
mucho gracias,
chris
Chris Owens is offline   Reply With Quote
Old February 5th, 2004, 08:00 PM   #2
Warden
It's either dirty playback heads, dirty record heads, or both. The only way to confirm which is to playback the tapes in another camera and check for the bars. Try running a cleaning tape through the camera (follow the directions with the tape exactely to the letter) and that should take care of the dirty heads. If I had to guess, I would say the high humidity probably contibuted to the problem.
Jeff Donald
Carpe Diem
Old February 5th, 2004, 08:00 PM   #3
Retired DV Info Net Almunus
Chris,
Sorry to hear of your trouble, particularly in such a remote place. Yes, we've heard of this problem with a variety of cameras.
If you have a cleaning tape in your kit, run it through (per it's directions) once or twice (no more). If you're luck it will clear the problem up.
If you're not lucky your heads may have become misaligned, not a problem you can fix or that will get better. The camera will need to be serviced.
Old February 5th, 2004, 08:09 PM   #4
Regarding the cleaning tapes.
Does it matter what brand?
Should it be the same brand as the camrea or the tapes?
Aaron Rosen is offline   Reply With Quote
Old February 5th, 2004, 08:12 PM   #5
Warden
No, the brand does not matter. This was covered recently in the Sony Forum. It was pointed out by a member that Sony had quit importing their brand and suggested that Sony suggested to him that he use another brand. It really makes no difference, just follow the directions included with the tape.
Jeff Donald
Carpe Diem
Old February 5th, 2004, 09:08 PM   #6
911
thanks for the info and responding so soon guys. unfortunatly some baggage was stolen and the cleaning tape was in it. is there any other way to clean the heads, and is the footage most likely destroyed.
thanks again,
chris
Old February 5th, 2004, 09:23 PM   #7
Warden
Put in a brand new tape and fast forward to the end. Put the tape in reverse search (play but in reverse). Do this for a minute or two and test record and playback. Repeat as needed, but if it doesn't clear up after 2 or 3 attempts you need more serious cleaning. Do not use the tape to record on. Do not play the old tapes if at all possible (old tapes may contaminate the heads again). If the machine had (has) dirty record heads there is nothing that can be done for the old tapes. If the playback heads are dirty then the previously recorded tapes will be fine.
Jeff Donald
Carpe Diem
Old February 6th, 2004, 01:46 AM   #8
Old Boot
Where are the bars appearing? If they are anywehre that could be croppped out in post you may have a solution. This aint a"sweet" solution to what have . .but maybe a solution to what you HAVE in the can. As to using the cammie again, IF the solutions provided above don't work, I wouldn't use the cammie again until it could be sent to the Canon Garage - yeah?
Look, you'd be amazed at what "aristic" solutions you can do in post. But if the really important "subject" is banjaxed, well you know the material you've got - yeah?
Any news team out there with a "spare" cammie you could use? Any news company or other pro that you could go begging to? Could you get a package - I'm serious - sent to you? I know and realise you are in the back of beyond, but stranger things have happened . . . . Call Canon INC and give them a real task! This could be a Customer Relation SCOOP! "Hey Guys! You wont beleeive what I've just pulled off?!?!"
. . . just some "sideways" thoughts . . . betcha gonna take a "back-up" cammie in the future - yeah?
Best regards,
Grazie
Old February 6th, 2004, 01:04 PM   #9
same here
Chris,
The only way I have found to keep this from happening is by using a large golf/racing style umbrella. I just built a pole that I can stick in the ground and I just adjust it to keep the shadows out of frame.
I also have the same cover for both of my cameras GL1/XL1s, and IMO it only works when the rain blows sideways and comes under the umbrella.
Sorry, I didn't offer a solution to your immediate problem but the above works for me in Alaska, and I'm sure it will work for you in South America.
Dan Holly
Anchorage, Alaska
Dan Holly is offline   Reply
