GL2 sound sync in NLE at DVinfo.net
Old October 8th, 2002, 05:38 PM   #1
Can anyone tell me whether the GL2 is one of the Canon cameras that requires sound sync adjustment for long clips in NLE (specifically, the "Sync Adjust Movies" feature in FCP3)?
Linc Kesler is offline   Reply With Quote
Old October 8th, 2002, 09:58 PM   #2
Warden
Yes, it requires the sync adjust to be on.
Jeff
Old October 8th, 2002, 10:05 PM   #3
Is this because of audio drifiting? Am I right in thinking that this happens on all DV cameras, and is only remedied by having a camera with locked audio (DVCAM etc)?
Aaron Koolen is offline   Reply With Quote
Old October 8th, 2002, 10:20 PM   #4
Warden
Yes, locked audio solves the problem entirely. It can also be solved by the NLE. During the copying of the data the NLE can count the audio samples (frames) and lock the audio in that manner. Most NLE's automaticaly count the audio samples. Some, like FCP must be told to count the audio samples.
Jeff
