What's out there in the way of in camera microphone mounts at DVinfo.net
Old October 28th, 2002, 07:29 PM   #1
Although I'm using my ME66 mainly on boom, I would like to mount it onto my XM2 as well for when I can't get an operator. What do you all recommend in the way of mounts and is shockmounting really needed on an oncamera mic?
Cheers
Aaron Koolen is offline   Reply With Quote
Old October 29th, 2002, 12:00 PM   #2
Try Lightwave Systems
Lightwave makes some excellent shock mounts and accessories. Try http://www.lightwavesystems.com
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old October 29th, 2002, 04:08 PM   #3
I use a beyerdynamic shockmount (the EA86). To be able to use the top-handle I use a so called "extension arm" from a Sony microphone (the MS908c).
This moves the microphone away from the camcorderbody just enough, and raises the ME66 a bit which keeps it out of the frame.
I have posted two pics of my setup :
http://www.xs4all.nl/~richardr/left_side.jpg
http://www.xs4all.nl/~richardr/right_side.jpg
Richard Raaijmakers is offline   Reply With Quote
Old October 30th, 2002, 12:58 PM   #4
Richard, Is that a beachteck adapter you are using? also, What type of lens cover are you using?
Thanks Joe
Joe Bowey is offline   Reply With Quote
Old October 30th, 2002, 01:41 PM   #5
Yeah it's a DXA-4P, which is a beachtek.
Old October 30th, 2002, 06:21 PM   #6
Retired DV Info Net Almunus
I second the Lightwave Systems endorsement. Worth checking out.
John Locke
SursumFilms.com
John Locke is offline   Reply
