Gl2 more focus problems vs outher camera's ? at DVinfo.net
Old February 6th, 2006, 04:49 PM   #1
Well I order just XM2 and read some threads hier about the focus of xm2
That de Canon xm2 is not one of the best focus camera's
I have not so much experience with the camera techniek
But what I wan't is switch with the subject with my focus
I want to get focus on the forefront subject and then on the subject behind as example.
Is this kind of things possible with these camera ??
Cengiz Ozgok is offline   Reply With Quote
Old February 7th, 2006, 12:39 AM   #2
Focusing
From what I understand, you want to focus on a foreground subject and then focus on something in the background.
Because of the wide-angle nature of the camera's lens, the only way to get this look is to set the camera as far back from your subject as possible and then zoom in on it. If possible, use the largest aperature (lowest f setting in manual exposure mode). Your subject should be clearly in focus, but the background blurry. Use the manual focus to switch the focus to the background.
Jon Jivan is offline   Reply With Quote
Old February 7th, 2006, 01:27 AM   #3
Cengiz,
I haven't found anything wrong with the focus on the XM2 - it's certainly no different to any other camera in it's class. The actual lens is very very good.
As Jon says though, to try to get differential focus between foreground and background will require a very wide aperture and certainly not to use the widest part of the zoom. This is nothing specific to the XM2, it's because it uses such small CCDs - and as I said, would be similar to any other camera of its type.
Robin
Old February 7th, 2006, 03:16 AM   #4
Thank you Jon and Robin
"focus on a foreground subject and then focus on something in the background."
This is exactly what I mean
I must think about that i have enough space between the camera and the subjects wich whant focus on it and enough space that I can zoom on the subject .
Old February 7th, 2006, 05:59 AM   #5
Sound like you want the foreground object in focus and the background out of focus, then you want to change it so the foreground is out of focus and the background in focus.
Not easy with the servo controlled focus because ther are no exact focus positions related to how far the focus ring is turned. It may take practice and several attempts to get it to your satisfaction. Also, as with a 1/4" CCDs, the camera has great depth of field, so the in/out of focus difference may not be as pronounced as you might like.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
