GL2 has a stuck tape, what to do? at DVinfo.net
Old June 2nd, 2006, 11:18 PM   #1
I got a call from one of my safari operators in South Africa tonight. I outfitted him with a complete GL2 rig earlier this year in an effort to begin building a video library for a promotional DVD I'm doing for him. He is getting an "Eject Tape" error message when powering up the camera. When he tries to eject the tape the transport sticks and will not eject the stuck tape.
I know this camera needs to be serviced but thought I would throw it out here and see if anyone had a fix I might try once I get there in mid-July. This camera has had less than three tapes run through it, it's new for heaven's sake!
Ever had this problem with a GL model and got the tape out without sending it to a service center? Thanks ahead of time for your help.
At full draw,
Tyge Floyd
Tyge Floyd is offline   Reply With Quote
Old June 2nd, 2006, 11:27 PM   #2
Images: 1
There are several threads here in the GL forum dealing with that very issue. Some of the cameras are nearly new, like the one you referenced. I was thinking one of those threads had a workaround for this problem.
-gb-
Greg Boston is offline   Reply
