Heads Up Monitor Suggestion at DVinfo.net
Old November 24th, 2006, 01:07 PM   #1
I've seen many posts and questions about a good solution for a heads up monitor for the GL2 and XL2... of which I own 8 and 2 respectively. I've had excellent success with the 6.5" PYRAMID LCD TFT which can be found on Ebay at around 65$/ea. It's intended as a head rest monitor. I've modified 12 of them. Simply remove the bezel, cut the DIN plug and solder the appropriate power and composite video connectors. Some cheaper units tend to artifact upon a pan or lack sufficient controls for the operator. This unit lacks neither. In my case, I've purchased a 1/4-20 to shoe mount adapter from B&H photo (bhphoto.com) and installed the units on camplex units for television production of sports.
Hank Freeman is offline   Reply With Quote
Old November 26th, 2006, 07:44 AM   #2
Fred Retread
Thank you for this very useful post and info, Hank. It hits me at a good time.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old November 28th, 2006, 10:00 PM   #3
Hank,
this would be a great piece to put together for the article section of DV info net. It sounds easy but I don't know if I understand what the bezel is and a picture or two of the soldiering job would be grand!!
I would like a few of these myself!!!
thanks again for a great piece of information.
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
