HV-30 LANC Support at DVinfo.net
Old June 25th, 2008, 09:00 AM   #1
HV-30 LANC Support
Just wondering if I saw a posting here regarding Stereo Sync ung a LANC support such as the;http://www.digi-dat.de/produkte/inde...tml#stefraLANC
Christo Aaron is offline   Reply With Quote
Old June 25th, 2008, 11:17 AM   #2
I don't believe any of the consumer grade Canon camcorders support LANC.
So nice product, but you would need something closer to the XH-A1 to get LANC support.
Scrolling down I did notice they have an adapter for the new(er) Sony camcorders,
going from Sony's Advanced Video Connector to the older 2.5 mm LANC connector.
150 EUR! That's what, about $225 USD? For an adapter? I'm flabbergasted.
Reread the web page. The price is for a pair, which brings the price/unit down to ~$112.
But at least it breaks out a composite signal for a monitor.
Last edited by Bill Koehler; June 25th, 2008 at 11:20 AM. Reason: Reread the web page.
Bill Koehler is offline   Reply With Quote
Old July 16th, 2008, 09:52 AM   #3
Even without the LANC controller, you can use a $3 optical cable to router your remote control to function as a LANC remote.
http://dvinfo.net/conf/showthread.php?t=94890
LA Color Pros Blog
Old July 16th, 2008, 09:59 AM   #4
Concerning the Optical Cables, it's a great and affordable solution in my experience. Could you not get it to work for you by buying/making some sort of splitter for the remote signal? As far as I know, HV30 remotes are not paired with a particular camera, meaning if you took the signal from one remote and split it into two fiber optic ends pointing at both cameras, both would react to the single remote.
Just an idea, and a DIY one at that, but it might be worth a try due to its affordability.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old July 16th, 2008, 03:21 PM   #5
Hi All,
I've used the "split the signal" option for controling two Cams, and for using two IR Remotes controling one Cam - on my DIY "Dual Extendable Control Handle" set ups.
Both options work fine for me.
Harold
Harold Schreiber is offline   Reply
