Jumpy OIS at DVinfo.net
Old October 23rd, 2008, 11:19 AM   #1
Jumpy OIS
I've recently seen a strange problem with the Image Stabilisation on an HV 30. Shortly after switching on (within the first 2 - 3 minutes) the camera will emit a loud click and the image jumps vertically. It may do this a few times before settling, and the jump is recorded on to tape or through FireWire. Not surprisingly, it doesn't do it if the OIS is switched off. This camera is quite new, with just a few hours of use.
Anyone else come across this or something similar?
Old October 23rd, 2008, 05:23 PM   #2
It may be a glitch with the camera but there have also been a considerable number of similar experiences reported here in the past and these have been attributed to radio-frequency transmission interference getting into the OIS circuitry and setting it off.
Nearby two-way radio comms and the newer data transmission systems to vehicle on-baord computers are one reported culprit and cellphone towers are another.
Old October 25th, 2008, 01:29 AM   #3
Thanks for that info, Bob. I've looked through about half of the 40 or so pages of posts in this forum but so far found only 1 similar instance where the image seemed to jump like mine, and haven't come across any reference to the external causes yet. Just as well you told me. I must say it looks like a specific issue with this particular camera to me, as I have used other HV30s in the same location without seeing the vertical jump. And that clearly audible CLICK from inside the camera worries me.
Old October 25th, 2008, 10:16 AM   #4
The "click" is apparently the fluid prism servo being driven the full distance instantly instead of more slowly following a command from the camera.
My vague recollection is that it has been previously reported on Sony VX2000/PD150, Canon XM ( I think it is called something else in the US ) and a Panasonic of some kind. The Canon XM lens casework looks superficially similar to the Sony VX2000 so servo circuitry for OIS may be commonly sourced.
The happenings in your camera may be something else again if other similar cams are not doing it. Did you have any sort of added microphone or headphones plugged in at the time?
Bob Hart is offline   Reply
