Canon HV30 still worth getting? - Page 2 at DVinfo.net
Old November 22nd, 2008, 03:54 PM   #16
So then would the CCD route be the more rounded choice?
I am currently renting a camra that is 3CCD. Its a Panisonic PV gs500 and it shoots ok..but not nearly as good as the clips I've seen from the HV30 posted above. However, my shots consist of fast pace skateboarding and boxing that was sort of in low light so perhaps that had an effect on the outcome of my footage.
Terry Lee is offline   Reply With Quote
Old November 23rd, 2008, 04:00 AM   #17
I think we've got to admit that CMOS technology in camcorders is fledgling technology right now, whereas CCDs are very mature. CMOS will undoubetedly take over if Sony have their way (as has happened alost entirely in the DSLR field), but for now they solve some aspects (smear) while introfucing nasty partially exposed frames when confronted by electronic flash.
Panasonic and Canon's newest cams are 3 CCD whereas Sony's is CMOS. Generally, where Sony leads others follow - though this didn't happen with El-cassette, Betamax, MicroMV and Minidisc.
tom.
Old November 23rd, 2008, 10:49 AM   #18
Hi all,
I think CMOS is here to stay.
CMOS is cheaper to make and use. Battery life is longer - that matters to consumers.
Sony and Red (and certainly others) are using parallel technology to mimic a mechanical shutter in as much as it can to reduce the effect of skew and rolling shutter. It's still there, but then in a focal plane shutter in an SLR it's there, too; it is what it is.
Which one (sensor) you want to get should be based upon what you want to do. I have an HVX200 for my professional work. The CCDs in it provide a film-like environment and can give me - with care - almost whatever I need to include frame rate when I need it.
But I also use small cameras with 35mm adapters, too. Those are CMOS. And again, with care - you'd think you're looking at a 35mm film.
Tools are what they are. Knowing how to use them is what makes the difference.
Mike
Mike Gunter
VideoTidbits.com
Mike Gunter is offline   Reply With Quote
Old November 28th, 2008, 01:43 PM   #19
Originally Posted by Mark Steele View Post
Dropped again:
Canon HV30 MiniDV 1080p HD Camcorder $550 - dealmac.com
Joel Peregrine is offline   Reply With Quote
Old November 28th, 2008, 02:51 PM   #20
Images: 1
The fact you can get an HV30 today for what used to be the price for a high end ZR is pretty amazing. The fact the the image quality bar has dropped so much in the last few years is just mind-boggling, especially with the 5DmkII and other DSLRs. I've been logging vacation footage I shot 7 years ago with a then-top-of-the-line Canon GL-1, and I keep wondering if it's all out of focus.
I don't think anybody would be unhappy with an HV30 at this price point. I'm seriously tempted myself.
Jenn Kramer is offline   Reply With Quote
Old November 28th, 2008, 03:43 PM   #21
The main advantages, generally of the Prosumer cameras over the HV20/HV30:
* Better Low Light Performance
* XLR Input
* Focus Rings instead of a small, fiddly thingy on the side
* Better gain control.
The main advantage of the HV20/30 over the Prosumer cameras:
* More portability
* Costs roughly 3-4 times less
Ways to compensate for the HV20/30's limitations compared to the Prosumer cameras
* Bring Lights.
* Buy an XLR adapter. (Around $200)
* Go with a 35mm adapter (Around $1500 but one for the prosumer costs just as much.)
Here's my recommendations:
Weddings: The low-light performance of the wedding just generally looks more professional and means you have to do less in post. Wedding videographers usually don't have a whole lot of turnaround time. Additionally, the increased weight of the prosumer lines means that handheld shots are smoother and easier to handle.
Documentaries: This is probably where the HV20/30 price/performance solution has it's greatest advantages. Buying two HV20/30s allows you to get multiple camera angles, good for interviews, or, with two cameramen, capture two or more different angles of the event. Additionally, the portability of the HV20 means that you can avoid a hell of a lot of scrutiny. A big jobby like the Z1 or XH-A1 immediately makes you stand out as "I am a serious media person. I am seriously going to ask hard questions that will make your candidate look bad. I've used the HV20 on airplanes without anyone caring, took footage of former presidents, etc. If people are likely to harass you for filming without a permit, they're less likely to give you a hard time when they see the little camera than when they see the big one - the big one means "you should have known better" and the little one means "you're just some kids - keep it clean, no harm, no foul."
Short Films: If you can control the lighting, go with the HV20, especially because you can do a two-camera solution and get a natural feel to conversations. However, if you think you can turn the short film around in a weekend, rent, rather than buy, two Prosumer cams.
Amateur filmmakers: Start with the HV20/30 and learn the basics before moving up to the big guns.
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1
Brian Boyko is offline   Reply With Quote
Old November 29th, 2008, 07:07 AM   #22
Beautifully put Brian - word perfect.
Old January 11th, 2009, 09:57 PM   #23
Thanks for the info Brian
For anyone in search for a better 35mm adapter solution for your 20/30 and soon to be 40s, there are cheaper alternatives. RNC35 and twoneils. Google these two names. I have heard good reviews about the twoneils adapters. But do your research!
Old February 8th, 2009, 03:55 PM   #24
I just ordered the TwoneilHd 35mm for my 2 hv30's I have ($227.00 each). From what I've seen that 35mm len delivers excellent results. The RNG35 is another very good 35mm for about $670. Here is a video of the Twoneil Winter on Vimeo and one with the RNG35 Christmas Eve To Day on Vimeo
Wilbert Thomas is offline   Reply With Quote
Old March 5th, 2009, 09:59 AM   #25
Originally Posted by Joel Peregrine View Post
I've only had HV30's for a few months but I can definitely vouch for the quality of the image. I match it up with Canon's A1 and I'm continually amazed at how the 30 holds up. You probably know this but many use 35mm lens adapters with the 30 that can go a long way towards improving the look. For short films where you have control of your lighting it would be wonderful as long as you acquaint yourself with the workarounds to eliminate any gain. I simply put a flash card in which allows you to check the iris setting with a press of the photo button while you change the exposure. As you open the iris you want to stop at the point the fstop doesn't open any further. At that point the camera is dipping into the gain to brighten the image. Its only then that the image will begin showing noise. The 30's noise isn't pretty.
Shot this yesterday. Just a few shots needed color correction for a blue cast when the shot was all in the shade.
~ Halloween 2008 ~
Joel, what a great film! great job on the cinematography, angles, etc. the quality looks great, not any noise from what i could see indoors! nice blacks. what did you export to? settings? it's a constant battle for me to export to a nice looking HD look. i liked his costume as well...cute kid.
Steve Rotter is offline   Reply With Quote
Old March 9th, 2009, 11:59 PM   #26
Hi Steve,
Thanks! Its a great little camera. (And a great little robot.) As you already know keeping the gain low with the exposure lock trick is important. I would have brightened the indoor scenes if I color corrected it at all. For encoding I use Telestream's Episode Pro - Flash 8 2-pass VBR. I think its encoded at 800 kbps but it might be 1000. It was shot at 24p so no de-interlacing was necessary. I really wish I could upgrade to the HV40's so I didn't have to transcode the HV30's footage to true 24p rather than being wrapped in a 60i wrapper. That's only necessary when I need to edit the footage with the XHA1 in FCP.
Old March 10th, 2009, 10:08 AM   #27
thanks Joel for the response! I appreciate it. I wound up ordering an HV30 last night, after days of reading and thinking. I just don't want to mess with any new format, as I had my nightmare fill with the TOD files from JVC when I had that HD7 for about a week. Great cam, really bad in low light. Anyway, I'm not familiar with the exposure lock trick, as I have not done much with tricks or what-have-you. I agree, you need to keep the gain low...but...what is the trick if you're in a darker room, or regular room, like a family room, or a church? Keep it at 0db, no gain, and at 1/30 shutter, then boost in AE? On my A1 I have the gain no higher than 6db. I need to read the manual, since, it seems to me, that when i boost to 6db, it jumps for a second, get some zebras, then it goes away...as if I made no changes to settings. But, i pretty much always shoot on 0db, 1/30 if indoors, and lowest aperture, and go from there. stupid question maybe, but, depth of field really doesn't work by adjusting aperture unelss you're in manual focus right? autofocus doesn't show DOF.... is that correct? because with my XH A1 i don't get DOF...shoot in auto only.
thanks again!
Steve
Old March 10th, 2009, 02:35 PM   #28
Keep it at 0db, no gain, and at 1/30 shutter, then boost in AE?.stupid question maybe, but, depth of field really doesn't work by adjusting aperture unelss you're in manual focus right? autofocus doesn't show DOF.... is that correct? because with my XH A1 i don't get DOF...shoot in auto only.
You're a bit confused Steve, but here goes. Firstly - it's always better to get the exposure correct at the scene of the crime rather than relying on post corrections. If you up the gain by 6dB then ok, it will get a bit grainier, a bit softer and the colours will be slightly muted.
But if you try and claw back a stop in post the damage is far worse, so don't go avoiding gain up when you really need it. It's there on the camera for a very good reason.
Manual or auto focus has no bearing on the dof whatsoever. You're not getting differential focus (I think you're trying to say) on your XH-A1 because you're letting the camera decide on the gain and aperture values. To get limited dof you need full tele, wide aperture, close focus and the background far away. Full stop.
tom.
Old March 10th, 2009, 06:59 PM   #29
Yes it is worth getting
Hi Ross, I just ordered the HV30 along with the H43 WA...both for around $710 with free shipping. We are using it along with our Z1U and EX1. It intercuts well with them both and I'll purchase an extended 3 year Manufacturer Warranty that Includes Accidental Damage Coverage for $109. It's not the EX1, but all of the above is about the cost for one 16GB memory card for the EX1. My experience is that the HV30 is a fantastic bargin and a terrific tool. Easy to edit format and low stress.
Hope this helps,
Craig
Key West – Florida Keys - ConchTV - KeysTV
Craig Hollenback is offline   Reply With Quote
Old March 11th, 2009, 07:55 AM   #30
tom.
Tom, thanks for the info. I have not played with DOF at all with video, even though I have been working with video for years. What I film never required it...bands, corp stuff, etc. With my digital photography I get DOF easily regardless of the shot. Seems like with video the subject has to be very close in the foreground and the background far away. How close would you say? As an example, I can photograph a bride who is 10' from me with the background all out of focus....with video.....doesn't seem like I can do that?! Frustrating. I agree with you 100%. You must get your shot set at the scene of the crime and fix as little as possible in post. Speaking of that, do you import all your video into After FX to process then render, export, import into premiere? That's what I would do. Lots of work right? I have never done much post work either with regular shoots...certainly not weddings....too long to do. I get the settings right during the shoot, white balance at each scene, etc.
Steve
