Canon HV footage - but can you guess which? at DVinfo.net
Old April 20th, 2007, 06:36 AM   #1
HV10 or HV20?
http://mirror.video.blip.tv/TheCreat...hSeafro103.m4v
It's not raw footage, so it may prove a tad tricky - but hopefully you'll enjoy the lovely scene captured here away.
Happy Friday everyone!
James Burland is offline   Reply With Quote
Old April 20th, 2007, 06:52 AM   #2
I'll give it a guess
Hmmm ... 50/50 chance of getting it right if you used just one camera. But it looks to me like you may have used both of them together then changed to progressive. One of the shots where you were focused close and the other where it was far away were taken while the subject was walking toward the light. The I.AF may be good but a guy like me wouldn't be able to frame it that fast at the apparent distance you took it. The PAL HV20 just came out so its possible you have it, though the PAL HV10 has been around longer. So I'd like to say the wide shot was an HV10 and the telephoto shot was an HV20.
Whichever it was, it's a nice video. I like the softness of the sun's rays and the four points on it. Did you put a filter in front of the lens?
DIY, 35mm, HV20:
http://www.primitivebuteffective.net
Mike Dulay is offline   Reply With Quote
Old April 20th, 2007, 07:09 AM   #3
Hmm, I'm getting a 'can't play file' due to possible missing codec.
Ken Ross is offline   Reply With Quote
Old April 20th, 2007, 07:32 AM   #4
http://phobos.apple.com/WebObjects/M...89174&s=143444
Above is the link to the Podcast, iTunes should play it back okay, it's an Apple TV Quicktime H.264 file.
Old April 20th, 2007, 09:53 AM   #5
Contributor
are you exporting to a full quality movie, and then using quicktime to export that using the apple tv preset? or just exporting out of fcp to specs that fall within the atv's limits?
Compositing is my life right now.
IMDB page: http://www.imdb.com/name/nm3596782/
Austin Meyers is offline   Reply With Quote
Old April 20th, 2007, 10:06 AM   #6
i'll say hv10. if it was a hv20, i would expect a little bit more noise. but just a little. and the hv10 gave a smoother, more unified look.
Jason Brown is offline   Reply With Quote
Old April 20th, 2007, 10:09 AM   #7
Hi, Your podcast say's HV10 so I will guess it's HV10 footage. ;-)
James
James Miller is offline   Reply With Quote
Old April 20th, 2007, 10:50 AM   #8
Jason, you've found the HV20 is a bit noisier than the HV10? I've got both and really haven't seen that.
Old April 20th, 2007, 11:19 AM   #9
Hi Ken,
only in low light situations. the gain has been increased from the hv10. i have a hv20 myself since the the pros out weighed the cons. also i can get rid for the noise in final cut and match hv10 footage, so i end up with a choice. you wouldnt notice it unless you had serveral comparisons with hv10 footage. I spent weeks A/B'ing both. almost went insane. anways, yeah.
Old April 20th, 2007, 11:22 AM   #10
Ah, got it...agreed. :)
