manual exposure in Cine Mode?
Hi,
Can I just clarify if I have any manual control over exposure once I enter Cine Mode. thanks, Wayne |
Yes you can.
The same EXP lock function works in CINE mode. You cannot separately adjust the iris and aperture, and you can't control gain, but you can at least lock the exposure.
The #1 thing to do is to get a mini-SD memory card and keep it installed at all times. Then you can press the PHOTO button halfway down and it'll tell you the current iris and shutter speed it's selected. Then you use the EXP button to slide the exposure up or down to find a balance of shutter, iris, and gain that you find acceptable. |
Thank you for clarifying this. I've been trying to use this 'lock exposure' fucntion but it's always dimmed and diasbled. I had no idea the SD card (or lack there of) was the reason. Gotta get myself a miniSD card right away.
Thank you. |
You don't need a miniSD to be able to lock the exposure. Exposure control is fully available with no memory card installed. So the card won't give you more manual features - it only gives you the possibility to get more info from the cam by pressing the PHOTO button and displaying the actual shutter speed and iris. Euisung Lee: as of why you weren't able to lock the exposure before installing a memory card, I have no idea. The lack of the card itself couldn't have been the reason, though. |
And in Cinemode it is limited what manual control you have.
In PAL land, you can do f/1.8 - f/8.0 with 1/50s shutter speed. In less light, you first add some gain for 2 or 3 f-stops worth, before the shutter speed start to slow down. For more light, shutter speed increases, and you stay at f/8. At very bright loght, you will get lower aperture, I have seen f/22 listed. Not sure if it is ND filter, or negative gain in software. |
I have noticed that cinemode in 25p changes the shutter speed downwards in lower light but cinemode in 50i does not. For me the shutter seems to stick at 50 no matter what I do!
