XF300 LCD problem - Page 2 at DVinfo.net
Old July 15th, 2015, 02:10 PM   #16
Re: XF300 LCD problem
Same here, do you just lose the date or what when the battery goes? How much was the replacement?
Alan McC
Alan McCormick is offline   Reply With Quote
Old July 16th, 2015, 01:44 AM   #17
Old Boot
No, not just the DATE/TIME, which is needed to be reset, but ALSO your personal settings. During this period I have been loading my previously Saved-To SD Card Personal Settings and imported them - each and every time I switch the main battery. PITA!
Costings? Well, I decided, as I do with all things was to get an Official quote from Canon. I did this by calling Canon Elstree first; made an appointment and took my camera in. At which point I was informed that I could wait till the engineer could ascertain the issue, confirm if a battery, if that was needed to be used, was in stock. I got an opportunity on the form to state an upper limit that I wished to spend. Canon would use that to inform me if it could be more.
Grazie
Old July 16th, 2015, 01:50 AM   #18
Thanks Grazie, sounds like a PITA as you say but not a "ball breaker" - just wish they had said something when I dropped my XF300 off.
I had the same procedure regarding costs and my LCD problem was £161 including courier back to me.
So what was the cost to exchange a battery?
Alan McC
Old July 16th, 2015, 02:11 AM   #19
Old Boot
As I said in my previous response to you - get an OFFICIAL quote from Canon.
Best regards
Graham
Old July 16th, 2015, 02:13 AM   #20
OK will do
Alan McC
