-   Canon XL1S / XL1 Watchdog (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/)
-   -   Black vertical edges when importing from XL1 (https://www.dvinfo.net/forum/canon-xl1s-xl1-watchdog/94-black-vertical-edges-when-importing-xl1.html)
briangeverd October 3rd, 2001 01:05 PM
I am getting two vertical black edges in my image area ( approx 20 pixels each side ).
It appears as if the XL1 is recording this way, and the problem is perpetuated through to import to editing software and export out to Quicktime etc.
When playing back through to a monitor, the black edges are lost due to image cropping.... but are a signifigant problem exported to Quicktime... as I am froced to use masks to block the lines.
Canon says they know of no problem, or setting regarding these black edges and say it may be a firewire problem or a defect in my camera. I have concluded it is not a firewire problem, so before I send the camera back for service ... has anyone have any ideas or solutions on this problem?
Brian Geverd
bobbyxl1 October 4th, 2001 12:22 PM
black vertical bars
it is perfectly normal.......when the video is played back through the a tv or monitor the bars are not visible, the only way to get rid of them is to crop.
Guest October 4th, 2001 05:23 PM
Black Lines
I tried to duplicate your line problem with my XL1s and was unable to do it. I am using Adobe 5.1 and tried several different picture formats. I fed the computer directly from the XL1s with the digital cable and still got no side bars. Weird.
Prof Chuck
codeloss October 5th, 2001 08:31 PM
I've heard of this before... I haven't used an XL1 that extensively, but the actual recorded image is only 708x480 (if I remember correctly). The narrow black bars are normal. My question is, does the XL1S still have these? From the above post, it sounds like it does not. Can someone confirm this? Thanks
Guest October 5th, 2001 09:50 PM
Black Lines
A friend has an XL1. We tried his camera on my editor and the black lines appeared on each side of the image. Somehow, the XL1s has eliminated the problem. He is really annoyed and now wants to get a XL1s (heh heh)
ProfChuck
Guest October 6th, 2001 08:11 AM
Frame width control with Adobe 5.1
I think I see what is happening here.
I am using Adobe Premiere 5.1 video editor. This editor has a setup feature that permits selection of the number of pixels horizontally and the number of lines vertically that will be captured. If these numbers don't match the output of the camera you will either get black borders or you will crop the image.
When you start 5.1 a new project screen comes up, click GENERAL SETTINGS.
A pull down will appear, click VIDEO SETTINGS.
From this screen you can select the compressor type, pallett, frame size, frame rate, etc.
I assume other editors have a similar feature. See if this solves your problem.
ProfChuck
Guest October 6th, 2001 08:18 AM
More on Black lines
Oh, and another thing, This relationship between pixel and line count in the camera and in the editor is responsible for borders or croping only when the video data is digital and has specific pixel location assignments. I doubt if the problem occurs when analog video is sent to the editor.
briangeverd October 8th, 2001 01:42 PM
Thanks to all for the experience and detective work on this issue. At least now I know it is a common issue for the XL1 rather than mine alone.
Regards,
Brian Geverd
