nanoFlash 6.5~20V - Good Call at DVinfo.net
Convergent Design Odyssey
Old March 30th, 2009, 07:08 AM   #1
Just wanted to say 'good call' on the voltage input.
I just ran into a situation where my new V-Mount batteries output 16.75 volts and the device I was powering died because it couldn't handle it.
The device was an LED light which I have since sent back for a full refund.
I'm looking forward to using the nanoFlash (early adopter) and decided to check the voltage to make sure it would work with my V-Mount batteries.
I was very happy to see it's rated to 20 volts.
Reel Inspirations - www.reelinspirations.com
Commercials, Dramas, Image Pieces, Documentaries, Motion Graphics
James Huenergardt is offline   Reply With Quote
Old March 30th, 2009, 11:13 AM   #2
Dear James,
Thank you for your comments.
We tried to plan ahead for a wide range of battery types.
Just be aware that our 20 Volts means true 20 Volts.
Just as a 14.4 Volt Lithium battery, right off the charger is more than 14.4 volts, so would be a 20 volt battery.
As such, it would be inappropriate to use a Lithium-Ion battery labeled 20 Volts, as the "just off the charger" voltage would be higher than allowed.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
