XDR SD Recording at DVinfo.net
Convergent Design Odyssey
Old May 18th, 2009, 12:46 AM   #1
XDR SD Recording
Anyone know when the SD firmware upgrade will be available?
Chris Atebr is offline   Reply With Quote
Old May 18th, 2009, 05:18 PM   #2
Convergent Design
Hi Chris-
It is imminent. It is very close, just a couple of extra lines at the bottom of the image. We are tracking down the problem now. I hope we can release the initial code this week.
Best-
Mike Schell
Convergent Design
Mike Schell is offline   Reply With Quote
Old May 27th, 2009, 08:48 AM   #3
We're in the final stages of testing a release which includes standard def support.
Here are some sample files if anyone would like to try them.
The compression is IMX 4:2:2 50 Mbit.
Avid told us that Media Composer does not support this directly - we are trying to get more details.
We've tested a couple other NLE's successfully - please let us know if something is amiss.
http://69.15.88.17/downloads/standard_def/sd_ntsc.MOV
http://69.15.88.17/downloads/standard_def/sd_ntsc.MXF
http://69.15.88.17/downloads/standard_def/sd_pal.MOV
http://69.15.88.17/downloads/standard_def/sd_pal.MXF
Tommy Schell
Tommy Schell is offline   Reply With Quote
Old May 29th, 2009, 04:16 PM   #4
Beta support for standard def has been posted as part of release 1.0.105, here:
http://www.convergent-design.com/dow...DR_1.0.105.zip
Tommy Schell
Old May 30th, 2009, 04:20 AM   #5
When will SD playback be available?. Not being able to check the first take back or allow the director to review is going to be difficult to explain!
Old May 30th, 2009, 08:19 AM   #6
Tommy Schell
Avid does support IMX 4:2:2 50mbs, but I believe it is with a Sony codec not Avid's. And Sony doesn't allow Avid to distribute the IMX codec without the Media Composer or Symphony software. The codec isn't free, its being licensed.
Calibrated Software has an IMX codec that can be purchased. I don't know if this helps or not.
Bob Willis is offline   Reply With Quote
Old May 30th, 2009, 10:01 AM   #7
Dear Bob,
Thank you for your insight.
We will be speaking with Avid.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
