Overscan progress at DVinfo.net
Convergent Design Odyssey
Old January 22nd, 2010, 02:04 AM   #1
Overscan progress
I am eagerly awaiting the promised overscan feature for the XDR. Any idea when we can expect that to be implemented and any idea of what overscan specs will be available?
Nic van Oudtshoorn is offline   Reply With Quote
Old January 22nd, 2010, 11:35 AM   #2
I think what you mean is the overcrank feature. I've heard that the feature is very close as we speak. As far as I know, there is no plan (or need) for an overscan feature.
Aaron Newsome is offline   Reply With Quote
Old January 22nd, 2010, 11:39 AM   #3
Convergent Design
Hi Aaron, Nic-
We have over/under crank working in the lab. We are waiting to complete 8-channel audio and then we will start the public beta, hopefully in the next week.
Best-
Mike Schell
Convergent Design
Mike Schell is offline   Reply With Quote
Old January 22nd, 2010, 02:53 PM   #4
Any idea what overcrank specs will be?
My apologies - I did mean overcrank, not overscan (and I do know the difference :) )
Old January 23rd, 2010, 07:52 AM   #5
Dear Nic,
For Over and Under Cranking:
Start with your camera set to 1080p30 (actually 29.97) or 720p60 (actually 59.94).
Then you set, in the nanoFlash, what frame rate you want the footage identified as for the editor.
Usually this will be 24 frames per second. This will be the standard play rate in the Non-Linear Editor.
Then, set, in the nanoFlash, the number of frames per second to be actually recorded.
This is a number from 1 to 30 for 1080 footage and 1 to 60 for 720 footage.
Anything under 24, if you set 24 frames per second as the timeline value, will be undercranked.
A value of 1, will be such that 1 frame a second will be recorded.
A value of 2, indicates 2 frames a second.
Anything above 24 will be overcranked.
720 footage allows one to overcrank to 60 frames per second. Thus when this is played back at 24 frames per second, the effect will be slow motion.
1080 footage allows one to overcrank to 30 frames per second. This is much more subtle slow motion.
With over and undercranking, you have some additional tools available for your camera.
Please understand that neither of these are "Super Slow Motion", but both can be useful at times.
We have this feature working in our lab. It will be in our Public Beta, which may be released next week.
We have delayed the Public Beta so we can include 8-Channel Audio in the same release. We met a major milestone yesterday in the development of 8-Channel Audio.
Dan Keaton
Augusta Georgia
Old January 23rd, 2010, 08:14 AM   #6
You mean 720p30 (or 25 for us PAL guys), right, Dan?
Also, will the nearest beta contain the promised record indicator on a loop-out monitor?
Piotr
Old January 23rd, 2010, 08:42 AM   #7
Dear Piotr,
I did mean 720p60 (usually 720p59.94) or 720p50.
If one sets the camera to 720p30 or 720p25, then one limits the over-cranking ability.
I have not know if we will have the Record Indicator (on the monitor outputs) ready or not.
Our Chief Engineer has been very busy with 8-Channel Audio.
Dan Keaton
Augusta Georgia
Old January 23rd, 2010, 08:45 AM   #8
Dear Dan,
When I need slow-mo from 720p in my EX1 (without the nano), I set it to 720/25p and overcrank to 50 fps (for exactly 0.5x), or even 60 fps.
This is why you got me interested - how does it differ when using nanoFlash? I'm obviously missing something here..
Old January 23rd, 2010, 09:27 AM   #9
Dear Piotr,
Yes, I understand the confusion.
If you want to record over or under-cranked in the camera, and not the nanoFlash, then set up the camera for over or under-cranking, provided the camera supports this function.
If you want to record over or under-cranked in the nanoFlash, then do not set over or under-cranking in the camera, just set it in the nanoFlash. Set the camera to either 720p50/720p60 or 1080p30.
Dan Keaton
Augusta Georgia
Old January 23rd, 2010, 10:00 AM   #10
Dan,
After a second thought, I guess you're right (well, you certainly know what you're talking about :)).
Old January 23rd, 2010, 10:10 AM   #11
Dear Piotr,
Thanks for the compliment.
I do try to be clear, but sometimes I fail.
What is nice, is that one can record Over and Under-Cranking in the camera, and record normal in the nanoFlash. And vice-versa.
While recording over and under-cranking in most cameras, normal 720p60 or 720p5, or 1080p30 is what comes out the HD-SDI port.
So, if one wants to record over and under-cranking in the nanoFlash, leave the camera setup normal, then one has a backup, in the camera in case the over and under-cranking is not exactly what you want.
The most important thing is that we are releasing this feature as a Public Beta, so our friends can test it, and report back to us what the like and do not like.
Dan Keaton
Augusta Georgia
Old January 23rd, 2010, 10:14 AM   #12
I think this is the key to clear any confusion, Dan - thanks!
Old January 23rd, 2010, 04:09 PM   #13
Thanks for that detailed reply, Dan. Will the beta provide "Super Slow Motion", ie 100 or 120 fps as I can get on my RED One shooting 2k? Also, I am using the XDR, not Nano, - will the beta be for both?
Old January 23rd, 2010, 04:30 PM   #14
Dear Nic,
We will provide a Public Beta for both the nanoFlash and Flash XDR. There may be a day or two delay, for one or the other, but our goal is to always release firmware for both simultaneously.
No, super Slow-mo, with footage over 60 frames per second is not possible with the nanoFlash. The HD-SDI connection is limited to 60 frames per second in 720p and 30 frames per second in 1080p30.
And, this values are also determined by the cameras capabilities.
In other words, most cameras can not exceed thes frames rates.
Internally, cameras can achieve higher frame rates, since they are not limited by the specifications and capabilities of HD-SDI.
Dan Keaton
Augusta Georgia
Old January 31st, 2010, 12:21 PM   #15
Presently (before the beta firmware is released that allows over/undercranking on the nanoFlash) if one were to set the camera to overcrank (and record to internal media) 60 frames on 720p30 are we going to damage the nanoFlash unit?
Andrew Stone is offline   Reply
