Convert video_ts to iso or img on Mac?
Hi!
I burn my dvd files with DVDSP, which makes them into a video_ts folder. But I want them to be in .iso or .img format, to be safer to play on all dvd players. Anybody knows an easy way to do this on Mac, like imgburn on a PC? Thanks Urban |
When doing your building and formatting, at the bottom of the screen, instead of selecting your DVD player, select Hard drive. This will create a disk image. Not sure, though, how compatible this is on PCs
Thanks, I found it, and I'll experiment.
I made the img in DVDSP and burned it by dropping it in the Finder window of an empty dvd-r and choosing to burn. But my dvd player says "Disc error" and spits it out. This it said also with another img (dvd) file from my Mac. But earlier I have made many img files from my PC, and they function very well in different dvd players (even better than only VIDEO_TS and AUDIO_TS-folders directly).
Are img files from Mac different than img files from a PC? The img file works in VLC on the Mac but not in the dvd (hardware) player. |
As I said earlier, I'm not really sure that Mac img files will work on your PC or the best way to utilize them
On your Mac burn the image file using Disc Utility. Works for me pretty much every time. Maybe on the PC side you could use Nero. I've done that with PC created image files |
Are you trying to burn a data disc or a video dvd? |
A way I know works, create your VIDEO_TS folder from DVDSP and an empty AUDIO_TS folder in a master folder. Use FFmpegX to create an .img out of the master folder (it will ignore whatever the master folder is called and the resulting image will be titled DVD_MOVIE.
Use disk utility to burn the .img to a DVD, the result will be playable in any standalone DVD player (that can handle DVD-Rs). |
If you read my first post you (hopefully) will see I'm trying to make a video dvd, playable in a standalone dvd player. :) |
Then select the .img file in the column and click the Burn icon at the top of the diosc burner window. Then just follow the instruction to burn the DVD. |
Success. Thanks.
