Tell me what is GOOD about FCP X - Page 4 at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old August 5th, 2011, 05:10 PM   #46
Re: Tell me what is GOOD about FCP X
Originally Posted by Brett Sherman View Post
Personally, I think they should ditch the whole storyline business as I don't think it helps anyone. Why can't you just put an effect on the outgoing clip and it just transitions to the clip that is shown next regardless of position. Just like fade-out works now, but with the ability to use two-sided transitions too.
I'll tell you once you get used to it it's brilliant.
Why? Here's an example.
You have 3 clips of overlay sitting on top of an interview. This form of editing is the style you've used across your whole timeline. With your interviews in the main storyline and your overlay (b-roll) on top.
Lets say you want to perform a single roller trim on the second of your three clips.
If you do this you know that ALL the clips on that video layer will be moved along. Creating a second storyline make those three shots independent and you can do what ever you like to them without worrying about destroying sync. Even better if you decide to move the interview further down the timeline just drag it down and the second storyline will go with it.
FCP X has a little way to go before it's ready for professional use, but the way it EDITs right now is far superior to anything I've used in the past. It's going to be huge.
Final Cut Pro Editor and DSLR-HD Shooter
www.rednail.com.au
Sean Lander is offline   Reply With Quote
Old August 6th, 2011, 06:58 AM   #47
Let's say for example you have an interview where in between sentences someone slams a door. In FCP 7 it was easy to just insert ambient audio in the audio track. It took like 3 keystrokes - bing bang boom - done. Now it's much more cumbersome you have to detach the audio, split it, delete the middle section, insert the new audio, reconnect everything together.
Fairly simple in X. Range tool, select door slam, lower audio to zero. If you want ambience after selecting door slam, find ambience in your source clip, mark in, ctrl 3, D.
Geoff Dills is offline   Reply With Quote
Old August 6th, 2011, 04:57 PM   #48
For cuts only editing and split edits, X is a breeze. Much better than FCP7. I am having problems with transitions not landing at the cut points correctly or the transition changes the cut points. Perhaps I am doing something wrong. Perhaps it's another version 1 issue.
Old August 6th, 2011, 05:51 PM   #49
have you changed your settings in the editing preferences for transitions from full overlap to available media?
Old August 7th, 2011, 05:06 PM   #50
Just did but I haven't has a chance to work with it. Thanks for the suggestion.
Is there a way to apply transitions to overlay graphics which seem to resist preset transitions unless in the main video track?
Old August 7th, 2011, 05:26 PM   #51
Sponsor: Westside AV
Turn them into a compound clip.
Command -W I think. Then you can add transitions.
Old August 7th, 2011, 06:41 PM   #52
Thanks, will experiment tomorrow.
Old August 8th, 2011, 05:07 AM   #53
Originally Posted by Jason Burkhimer View Post
The optical flow time remapping is a very nice alternative to Twixtor, so you can save money there.
I curious how FCPX's fast/slowmo compares to Twixtor. I've been in contact with Re:Vision and they tell me that Apple haven't yet given them what they "need to make Twixtor work in FCPX" and want us to voice if we would like Twixtor to work in FCPX here: Apple - Final Cut Pro - Feedback
Perhaps FCPX's built-in fast/slowmo is already as good, if not even better than Twixtor, and that's why Apple is now sitting on the fence..?
-- peer
www.NoPEER.com
Old August 9th, 2011, 05:15 AM   #54
Don't make a compound clip, make a secondary storyline cmd G.
Old August 9th, 2011, 05:17 AM   #55
-- peer
FCPX optical flow is as good as it gets for slomo IMHO.
Old August 9th, 2011, 09:30 AM   #56
That's interesting. I tried using the optical flow slowmo for a clip, and found it to be the worst of the two options. It had all sorts of crazy motion artifacts like you typically see from bad twiddle clips. But when i slowed down to the same speeds with the other two options, they both looked better, which was confusing to me. Are there certain situations where optical flow doesn't work as well as the others?
Fullerton Images - Vimeo - FaceBook
Ben Fullerton is offline   Reply With Quote
Old August 9th, 2011, 12:24 PM   #57
The best is Kronos, a plug-in from The Foundry which utilizes the GPU to accelerate it.
Old August 9th, 2011, 05:34 PM   #58
That works fine. However it seems that the program defaults to "full overlap" at every boot. A nuisance but workable.
Old August 10th, 2011, 07:33 AM   #59
I would suggest trashing your preferences and see what that gets you. I'm about to try Preferences Manager, a free app from Digital Rebellion to use for saving mine.
Old January 11th, 2012, 06:31 AM   #60
Have you done a comparison between Optical Flow and Twixtor?
-- peer
www.NoPEER.com
Peer Landa is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
