Compressor not compressing - Boris the culprit?
I recently purchased a download copy of the Boris Continuum Film Process plugin.
Boris Continuum Film Process :: Digital Juice I used it for some color correction and image softening and then sent the sequence to Compressor. Compressor basically stalls out and doesn't do anything when I hit Submit. In Batch Monitor the progress bar doesn't even start to move and it says "Unknown Time Remaining". I mention the Film Process because that's the only thing that's different about what I'm doing now vs. what I was doing before Compressor quit working. I was able to output a Self Contained .mov file from FCP to Quicktime and then render that through Compressor, but that's an extra step I'd rather not have to take every time I want to use Compressor. Here's my setup: 2009 Mac Pro Quad 2.66 FCS 2 Sequence is ProRes 422 (HQ) 1440x1080 30p Rendering to H.264 in Compressor Any thoughts? |
Re: Compressor not compressing - Boris the culprit?
I've had a similar problem with Compressor. Here are the things that have fixed it for me in the past.
- Restart Compressor - Open Batch Monitor and cancel process - Restart entire system - There's a bug in the Matrox MXO2 software but it's been fixed recently. I needed to upgrade the software/firmware. |
Reset Compressor
Similar problems on both G5 and Intel. Below are a few things I found digging around sites. Compressor now appears to be working good for now.
System Preferences > Apple Qmaster > Stop Sharing In Compressor, select the menu item Compressor and Reset Background Processing. Close System Preferences and Compressor. Open Terminal > cd /var/spool/qmaster/ > delete all the folders/files before you reboot. Reboot. Open Compressor to see if it now is working correctly. If all is well enable Qmaster: System Preferences > Apple Qmaster > Start Sharing |
