Trim Operation??? When speeding up
Does any one else get this error when trying to speed up or slow down a clip?
"Uable to complete command. A conflict occured during a trim operation." Any ideas? Thanks |
yep I get this all the time. It happens to me when the clip butts up against the clip before it and the clip following it.
Drag the clip to the end of your sequence (so it sits alone with no clips either side of it) and change the speed there with no fades or anything attached. Then drag it back into the timeline and adjust all your other clips accordingly. I don't know why it happens, changing the speed of the clip seems to be too big a task when it comes to computing the new transition from/to the sped up clip straight into another clip. |
Thanks for the reply. Yeah, I just figured this out yesterday. When you change the speed of a clip it either pushes forward everything after it (for slo-mo) or pulls everything back (for speed up), but if you're dealing with multiple clips and you don't have room on a track for the movement then you're going to get that error. My work around was to push it up to a new track and lock everything else down.
Peace! |
Another technique is to create a "scratch sequence with the same properties as your main timeline. You can copy the clip from your main timeline to the Scratch sequence, edit, and copy it back. It will stay in the same relative track.
Yeah, I think that scratch sequence is a good idea. I don't want to able able to turn the warning off just in case I overwrite something in the process. If I have a project were I'm doing a lot of speed changes I'm going to do the scratch thing. Good tip.
http://rippletraining.com/movies/ken..._speed_960.mov
Brillinat technique! you can change speed without changing duraion of your clip. |
