'Project unreadable or may be too new' Message
Hi,
Have tried to open a couple of old projects from within FCP documents. Unfortunately a number of them are not having any of it - I'm getting the following message: http://i56.photobucket.com/albums/g1...FCPmessage.jpg "This project is unreadable or may be too new for this version of Final Cut". I've recently backed up and trashed some quicktime movies (tons of exported clips from FCP) but other than that I can't think what mau have caused this...although I've recently added a new external hard drive but have not moved any FCP/Quicktime files/folders over there...only music via iTunes. Possible that some of these projects which contained music files from iTunes may be causing a conflict? I created an alias when moving iTunes but that works fine on it's own. Thanks. |
I've got the same problem. It occurred today after I erased an old backup hard drive, which apparently had some file that Final Cut can't live without. My theory is that it's a sequence (my logo animation, I believe) which at some point I must have dragged from an old project into my current new project template which I've based each new project upon for the past few years. So now suddenly all my projects from the past few years won't open!!! I get the same message "This project is unreadable or may be too new for this version of Final Cut" and I called Apple and they were of no help. =(
Does anybody have a clue as to how to get past this? If I can't open my FCP projects up I'm in big trouble... |
Oh, and one more thing: I can also still open the projects if I log in to OSX as a different user. So I don't think the problem lies with FCP itself, nor with the project files, since those are unchanged and the only thing different is the user I'm logged in as (or the computer I'm using, in the case of my MacBook)
Seems like this is an uncommon problem given my search results but it just happened to me after I added a new Lacie Rugged drive 320 GB 7200 rpm to my MBP.
I'm going to try the new user approach, trashing preferences didn't help. The good news is that the second to last autosave vault file will open so failing any other solution I haven't lost too much work. My question is: Are there any issues to be aware of if I continue to work from this autosave file. I'm assuming not, but never having done it before and having a deadline for monday I'd like to be sure. Will it autosave correctly? Time will tell I guess. Thanks |
I've also received this warning when Auto Update from apple updates the pro applications in the middle of a project. Watch out for that too. -C |
