June 20th, 2006, 05:53 PM | #31 | |
Are you pretty sure Steve? Even when Focus come out with the update? Thanks, Carl |
June 20th, 2006, 07:10 PM | #32 |
Upgrading the drive
Hi Matt,
Can you please explain how we will upgrade the drives? Will we download the upgrade and then connect the drive? I own the 40 gig version and we are very excited about this upgrade. Thank you for such a cool tool. Tom www.tomchaney.com |
June 20th, 2006, 08:09 PM | #33 | |
HDV is what the JVC shoots. JVC uses HDV 1 (720P) which is recorded to tape as a 6-GOP. Each 6 frames contains only 1 full frame called an "I" frame. The next 5 are made up of B and P frames that are based on the information of the surrounding frames. The Apple Intermediate Codec (AIC) transcodes each of these GOP's into 6 independent frames. This is why HDV takes up less space than AIC. This can cause lag in real time capture because it takes a lot of processing power to transcode the HDV to AIC on the fly. The Firestore drive does not have the power to do this. HDV on the otherhand is easy to capture, but when editing requires more processing power because the GOP structure gets damaged and needs to be reinterpreted. Without a VERY fast computer even dissolves may need to be rendered for real time playback. FCE can only do the AIC. FCP is able to do this and edit the HDV Natively in its GOP form, but it needs a Quicktime wrapper (hence the update) since it cannot read a pure .m2t file. I owned Final Cut Express HD and did this. It came with Soundtrack. I bought the Soundtrack Pro upgrade ($100, though it may be hard to find now) and then sent in the disc with $200 and got the entire Final Cut Studio from Apple. One of the best purchases of my life. You can also do this with Motion 2 and DVD Studio 4. They may be hard to find, but in the long run will be cheaper than paying for the studio in full. Also, one of the best things about the JVC HD-100 is that it does 720/24P. While I am not sure you use it or not, but FCE DOES NOT support 24 Frame editing. Also, to get the "Soon to be released 720/24P HDV Support" FCP release from Apple, you are going to have to have a Crossgraded version. I hope I helped you understand the whole thing. Good luck man. I just ordered the DR-HD100, and I am a big fan of Direct-To-Edit. I wouldn't part with it so soon. You are better off trying to get Final Cut Pro/Studio. |
June 20th, 2006, 08:49 PM | #34 |
Focus Enhancements
Thanks for the great explanation Steve.
To address Tom's question, you will be able to order the QuickTime update from the Focus webstore ($39). You will be sent a CD with the new version and the new manual. To update, simply copy the .bin file which will be on the CD to your DR-HD100 and run the OS Update function in the DR-HD100 SETUP menu. After a reboot, the new software will be loaded. Hope that helps, Matt |
June 21st, 2006, 04:14 AM | #35 | |
Can you canswer my question about the Camera Mount Kits? I'll write it again here: There are none listed under the DR-HD100 Accesories on the Focusinfo Webstore Page. So I figure it is the same Cam Mount Kit as the FS-4. First, is that correct? Second, should I get the High Cap Kit or the Regular or does that depend on which Li-Ion Battery I plan on using? |
June 21st, 2006, 04:29 AM | #36 |
Steve,
I called Focus Enhancements and they talked me through ordering the camera mounting kit listed for the FS4, it works. And for the record, it was really only a manfrotto hot shoe attachment that made it work. I would bet you can order the hot shoe attachment somewhere else for less money. Matt, Thank you for answering my question. Tom www.tomchaney.com |
June 21st, 2006, 05:04 AM | #37 | |
Carl |
June 21st, 2006, 10:31 AM | #38 |
DR-HD100 and Avid Xpress Pro HD
Here I go again. For GODSSAKES someone please answer me this: Is it possible to import 24p HDV (.M2T) files into AVID EXPRESS PRO HD? I've tried it so many times to no avail. I keep getting the friggin' "not compatible MPG file" error. Somebody tell me, what's up with this SHHH... how can I import .M2T files into Avid Xpress Pro HD? Is it not possible? Should I be recording my 24p footage in a different format? Thank you.
I will be KING! |
June 21st, 2006, 11:26 AM | #39 | |
June 21st, 2006, 02:04 PM | #40 | |
I will be KING! |
June 21st, 2006, 04:36 PM | #41 | |
July 13th, 2006, 12:19 PM | #42 |
Matt, any news about the HDV - .MOV Quicktime Wrapper?
July 13th, 2006, 01:38 PM | #43 |
Focus Enhancements
It is in test. Hoping before the end of the month.
I will post when it is available. Matt |
July 13th, 2006, 05:56 PM | #44 | |
August 11th, 2006, 11:26 AM | #45 |
Any idea on when an update will be released, so I can edit m2t on my mac pro?
