I'm thinking of switching from Vegas to Edius
Hey all,
I'm thinking of switching from Vegas to Edius here pretty shortly as we have decided to go with the P2 native workflow. I'm not really interested in converting all of our footage to some other format before I can edit it. Time is money. Can you guys weigh in on a few things? 1. What's the learning curve for Edius if I'm a former vegas user? 2. How are the transitions and effects in comparison? 3. How does the workflow compare? 4. Can we edit from the timeline? 5. Does Edius take advantage of dual and quad processor systems? Any other info that anyone has would be great. Thanks! Kit |
Hello Kit
1. For all I know I never really liked Vegas that much so I can't be really objective about it. All I can tell you is that having worked intensely on a bunch of different platforms, from Premiere to Avid, I believe Edius is by far the best I've used. You won't find it hard to adjust. Ask someone who has it to let you play with it for a while. I'm sure you'll be amazed. 2. Pretty much the same, if not better. Either drag and drop or with a keyboard shortcut and fully adjustable from the effects tab. Buy a colour-coded keyboard, they are a life-saver. Even better, since keyboard can be customized accordingly, buy an Avid Xpress Pro colour-coded keyboard and arrange shortcuts accordingly. Also, you'll have to work with two monitors and you can arrange, save and load as many layouts as you want. 3. It has its differences but they are not that much to scare you away. My most beloved thing is a that all tools are in front of you. No submenus, no new windows for an action, it's all there and waiting for you. I wish I could show how nice it is but you're gonna have to see it for yourself. 4. I'm not sure exactly what you mean. My guess is dragging all material to the timeline and then trim, re-arrange and so on. The answer to your question is absolutely yes! But why would you edit straight from the timeline? That's why source and record monitors are there for :-) 5. They certainly take advantage of the Dual Core, even double Dual core processors, but for the moment I don't think there is any editing software that takes advantage of the Quad Core. But, don't let me fool you. Simply go to www.canopus.us, click on Support and e-mail them about that. They'll let you know for sure, especially now that the software is in Grass Valley's hands. Finally, keep in mind that Edius Broadcast in its newest version, 4.54, supports every format in the market, including P2, XDCAM, AVCHD and absolutely no conversion is needed to import and start editing. To give you an idea, recently I had to use avi footage from a camcorder's SD card. All I had to do was import and start editing. No layout change, no conversion. You simply add the footage to the bin, from then to the timeline and you start editing. I'll try to post a picture of my screen setup to give you an idea hope this helps |
Themis,
Thanks for answering my questions. I have a demo copy that I am going to try out this weekend. When I say edit from the timeline, that's what I mean, dropping effects and doing cuts. Of course you need an external monitor, just wasn't sure how difficult everything is. I like vegas, but it doesn't natively support DVCPRO HD and I sure as hell am not going to waste time converting everything. Thanks for the info, I appreciate you taking the time. I'll let everyone know more about my findings this weekend. Kit |
1 Attachment(s)
Here it is. Check the attachment to see a very flexible interface, at least in my case. Timeline on the left screen, monitors, bin and tools on the right. notice how everything is just one click away... :-)
I almost got the same setup as you Themis, but I also got the Vectorscope always opened for quick colour correction.
I loke to underscore what Themis already writen... I have worked in Premiere for 4-5 years and change to Edius this December. I still edit in SD but the speed in Edius with a videocard (I use DVX) is crazy... Most of my videos are with alot of colour correction and stabilazing plugins and exportime is realtime... thing that tock me 2-3 hours in Premiere to export take 20 minutes now. Markus Nord |
One thing that Edius are much better on then Premiere are colour correction, the quality is much better. Markus |
What I like about Edius is that absolutely everything happens much faster and easier. But I have to give a big credit to Premiere for its integration with After Effects and, mainly, Encore DVD. The incorporation of Encore CS3 inside Premiere Pro CS3, though, was, in my opinion, a punch under the waist. |
that my point of view... mybe I missed some thing... cheers for the chat Markus |
Does it need to be either/or?
I'm running Edius 4.5 and Vegas 7 (so far, I haven't seen the need to upgrade). For straight editing, I like Edius. The play/record format works well for composing a story. I like the way Edius displays editing information (in/out/duration etc). Other stuff just seems to lend itself to Vegas. I hate the way Vegas displays editing information. I'll sometimes start a project in one and then decide that the other would be a better fit. |
Markus. Edius uses 3D PIP to do a lot of things that motion or keyframed crop does in Vegas or Premiere. Edius also has a tool called Layout that can apply a crop/resize the image. In comparison to Vegas 8 or CS3, Edius 4.5 is a lot faster on the same machine. I have all three of these on my AMD Athlon X2 4200, a slow dual core by todays standards. Edius will output in realtime from the timeline to DV for most things something that neither CS3 or Vegas can do. One can mix any format on the timeline and change the project properties at will too. As an example mix HDV and DV and output both a HDV file and then change properties and output a DV file. As a video editor it is my choice, for audio, Vegas 8 and for titles CS3 still has the edge. I got CS3 for ability to author to multiple formats in Encore but have yet to do so and still prefer DVDLab Pro2 as an authoring program.
Ron Evans |
Thanks for the tip Markus |
Ah good, an Edius expert or two. I'm thinking of deserting Premiere for Edius but one thing I'd like clarified if possible.
At the moment I'm editing in SD and like the add-on Canopus 'Speed Controller' that allows me to vary the speed of a clip. So I can sine wave smoothly from 100% speed down to (say) 27% and back up to 100%. Looks wonderful. Of course I have to work on the audio a bit (generally keeping it at 100%). My question is, can I do the same thing using Edius? Demos I've seen show 'nearly' the same thing but not quite, where speed reductions have to be counterbalanced by speed increases within the clip. Not what I want. tom. |
Hi Markus
Yes layout is not keyframable but 3DPIP will do what you want with keyframes. Anton's site http://www.videoproductions.com.au/h...equipment.html or the Canopus Forum http://ediusforum.grassvalley.com/forum/ is a good place for information. For Tom I have not used the Speed Controller so am not sure if it is currently the same as in Premiere CS3 for instance. Ron Evans |
