Looking for simple jib recommendations.
Hi guys. Done a search, not much turned up other than the Skycrane.
I'm looking at a jib that can mount to a standard tripod (I have a manfrotto) and can privide me with pan and tilt. It doesn't need to be huge. 3-4 meters would be a good size. Does anyone have any recommendations? The alternative is to look at building one - does anyone know how good the Killer Camera Rigs book is? Cheers Aaron |
Hi Aaron, not sure whether or not they've got dealers in NZ (I think they're a UK company) but the Hague Multi-Jib's not bad at £699 inc. VAT.
100mm bowl, optional 75mm step-ring (which should fit your Manfrotto, at a guess) and modular design allowing 2', 6' or 10' from pivot jib action - maximum extension from ground is somewhere around 14' (just over 3m), when mounted on a tripod. Link: http://www.b-hague.co.uk/Multi_Jib.htm I'd avoid anything you can't mount a fluid head on (such as drive-from-rear cheap mini-jibs, but I doubt they'll be long enough for you anyway). |
Hi Aaron,
I'm probably pretty biased since I wrote "Killer Camera Rigs". Two of the cranes in the book can tilt, but not pan. In Volume 2 (due out at the end of the year) will have a motorized pan/tilt mount. The comments on the Praise page of DVcameraRigs.com are legit from people that ordered the book. You can take a look here: http://dvcamerarigs.com/praise.html Dan |
