Cine-lens adapter - quick straightforward question...
We've got it coming in, and have the intention of eventually picking up a 16mm lens....
but in the short term, do lenses from 35mm film SLR cameras mount? |
Quick answer - yes and no. It depends.
Provide a little more info about what you're thinking and we'll try to help. |
Sorry - the adapter being the JVC model, and the lenses are Canon FD type. Fingers crossed....
I don't have any need to use 35mm lenses so I haven't really looked into this, but I have a vague feeling that somewhere i've seen that there was some issue with Canon lenses and back focus that prevented them from working this way.
I also found this on Wikipedia. But this may not be relevant to mounting on a JVC. Using FD lenses on other mounts The flange focal distance of the FD mount is smaller than most other lens mounts, meaning that it is impossible to mount an FD lens onto most other cameras with an adapter and maintain the same focusing distance. Canon made an adapter containing corrective optics allowing its larger, more expensive FD telephoto lenses to be used on EOS bodies. This adapter functioned as a mild tele-converter, and could not be used on normal and wide-angle lenses. Canon produced this adapter to ease the initial cost of conversion for those with expensive collections of long FD telephoto lenses. Due to the limited number manufactured, these adapters remain sought-after, with used models selling for $1000 (the orignal "new" price was $250!). A few companies have started making EOS-FD adapters, however the image quality (especially at high aperture) is greatly reduced.[6] Mechanically skilled photographers have, however, reported successfully retrofitting FD lenses with alternative mounts.[7] FWIW. Hope I'm wrong |
However it would probably be possible to machine a direct FD to 1/3" bayonet adapter much like the popular Nikon F adapters that are out there. |
I thought the Nikons had greater FFD so were more amenable to this kind of mounting technique.
Again, not one of my problems so I really don't know for sure. |
I appreciate you guys really looking into this!
I have a Nikon to 1/3" adapter and it is great but you get about a 7.2X crop factor... I am currently looking into ways to correct the crop factor, but am just at the beginning of my research. |
John-Paul,
I'm constantly amazed at how helpful the folks on this forum are. I remember someone having a lighting issue and someone else who lived in the same city volunteered to drop by and help him with the setup. Glad to have you with us. (And I hope you find a solution to your problem, although it seems to be looking a bit bleak) |
There is an interesting PL mount adapter at RafCamera for m42 lenses. If you get the right m42 lenses (pentax and older zeiss) they will sit 9mm or so inside of the adapter and let you reach infinity focus. Might be worth a try if you need some cheap lenses just to get it to work.
I will look into this!
