Attn MAC USERS: HDVxDV now supports JVC 720P24 and Timecode!
I happened to check out HDVxDV's website today and noticed the animated banner promoting the fact that it now supports the HD100 in 720P24 mode.
They also stress that when the new quicktime movie is created, it will maintain TC of the camera original. That is good news! This solution will work for Final Cut Pro and Avid users. http://www.HDVxDV.com Quoted from their site: Quote:
The other nice thing is that the workflow is very simple compared to LumiereHD. Just capture your clips, batch export them to your desired codec, and then drag them into your FCP project. This will work with any version of FCP. |
Dammit, I just bought the Lumière software, which is actually a bit time consuming. Did you try this new one? If so, how do you like it?
Thanks for posting Tim =) |
HD 24 fps
Hi!
I am new to the HD game. I have the JVC GY - HD100U and the Apple Mac FCP. Question : 1) When I capture 24fps, how do I convert that to read in FCP and have the output in 24fps quality? 2) I have heard of Lumiere and HDVxDX and tried the trial version of HDVxDX. Does that maintain the 24 fps quality when you convert with the 720p or 1080i mode? 3) Which software is better? Does Lumiere have trial version? Did not see it on their website. 4) I have read the tech explanation of 720p and 1080i. Practically what is the difference to the end user. All I want is broadcast quality output? Thank you. Nitin Sawant |
As for which is better, it is subjective opinion. In my personal experience, we purchased Lumiere HD (v1.6b2) a couple of weeks ago and I have basically found it to be useless in its current beta form. I don't feel comfortable capturing without TC, and after I capture my first clip, the transport buttons "gray out" and I have to restart the app to continue. It is definitely beta software (that we payed over $200 for.) I was able to remove the pulldown from a bunch of m2t 720P24 captures I had made earlier with DVHSCAP - so at least that works. With that said however, the workflows are different and both are in development. Lumiere HD does offer the ability to record back to tape - but I haven't gotten that far yet. Also, with the current beta version of LumiereHD a lengthy 15-step process is required to capture and convert your footage with sync audio into a usable format for FCP5. HDVxDV (v1.024) is very simple and straightforward. You just capture and convert, then import all of the clips into FCP. Audio sync is maintained no problem. The K.I.S.S. approach makes it the current winner in my books. They still need to work out a little TC bug, but the support staff is very quick to respond to emails. In either case you can keep your original m2t files in a safe place and use a low-res codec for real-time offline, and then re-convert to a broadcast codec and reconnect the new clips. Quote:
Personally, I think the end results will ultimately be better with 720P because so many people are buying LCD and plasma. These technologies are inheritly progressive scan, so no interlace to progressive conversions need to take place. There are many threads all over dvinfo regarding the pros and cons of 1080i vs. 720P. You should do a search. |
Testing the Software
I've been working with the trial version of HDVxDV for a couple of days and it seems to work very well. I've been making DVCPRO HD files. The frame rate comes out to pure 24fps and not 23.976. When I've made a project file in FCP from the preset menu, the timeline is set for 23.976. I've been changing this to pure 24fps.
Does anyone know if the files coming out of the JVC are 24fps or 23.976? I couldn't find it in the manual. If it's 23.976 and HDVxDV is creating 24fps files, am I doing something wrong or is it the software? Thanks, Dave Dessel |
1) How does one find out if the QT file exported out of HDVxDV is 24fps?
2) When you import it FCP, edit it and export it to a QT file again - how do I know what fps I am getting on output? Thanks Nitin |
You shouldn't change your sequence to 24fps, instead open cinema tools and "BAtch conform" your quicktime files to 23.98. |
Tim,
Thanks much for the workaround on the 24fps issue. HDVxDV is a great solution for editing 24p. It's simple, fast, and the quality seems first rate. -Dave Dessel |
Wishful thinking scenario: Apple will release a major update to FCP5 at Macworld in January that includes a 720P24 capture preset. Then simply batch capture the project based on TC. Maybe HDVxDV or LumiereHD will add batch capture functions as well? |
I've moved the posts concerning the eternal Mac vs PC question into its own thread in the proper forum.
Go here to continue the conversation: http://www.dvinfo.net/conf/showthread.php?t=54543 |
Has anyone had any TC issues? I'm finding that the resultant TC on the 1.024 version is not the same as on the camera original (build 1.024 under OS X 10.3.9)
Brad seemed surprised that this was the case, so I wanted to get some other results from those running Tiger. |
Analog capture via B works fine to DVCPRO HD. Now you would think you you choose FireWire control by simply choosing HDV FireWire. But noO. It claims you must be capturing HDV to use HDV Control. I used to use this trick with the first gen JVC which had DV control. You've got an "assistant" :) Now that makes an EDL really useful. I had never considered such an option. |
TC and deck control go hand in hand and seem to be a running theme with HDV and especially the JVC gear.
Sean |
