Review of Quyen Le's Letus35 - Page 3 at DVinfo.net
Alternative Imaging Methods
Old September 12th, 2005, 09:46 PM   #31
Maybe most/some of us are still waiting on lenses? Mine should be in Friday according to UPS. Chomping at the bit myself.
Eric Brown is offline   Reply With Quote
Old September 13th, 2005, 06:30 AM   #32
Images: 1
I'm currently filming an advertisement with my adapter for film class. The due date is the 20th, so I should have footage up around then.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old September 13th, 2005, 07:53 PM   #33
I believe Quyen will be making mine tomorrow (Wed) and when I receive it I'll be shooting some test footage using my DVX100. I'll post something soon after that.
Jon
Jonny Dee is offline   Reply With Quote
Old September 13th, 2005, 07:57 PM   #34
Looking foward to seeing it. Something we really need is some test footage. May you be the first to provide it.
Wayne
Wayne Kinney is offline   Reply With Quote
Old September 13th, 2005, 08:46 PM   #35
How much light loss with this adapter?
Michael Maier is offline   Reply With Quote
Old September 13th, 2005, 09:14 PM   #36
I think Quyen said it was about one stop.
i can't yet see Productions
Riley Stearns is offline   Reply With Quote
Old September 13th, 2005, 09:25 PM   #37
it's a goo design, I have a beta unit for the dvx I am shooting some HD with the unit, looks good so far but I am going to try some new achromats and see if we get better/shaper results
Obin Olson is offline   Reply With Quote
Old September 13th, 2005, 09:27 PM   #38
About probably means a little more than one stop, or he would have said under 1 stop. Hmm, how the M2 does in order to lose zero light?
Old September 13th, 2005, 09:29 PM   #39
Obin, you are also using a micro35, right? How do they compare in your opinion? Do you feel the Letus35 is a better or more efficient design with the vibrating glass? How big is it by the way? Could post some of your HD clips done with the Letus35?
Old September 13th, 2005, 10:08 PM   #40
I will not compare untill I get a proper achromat, lets just say I like the design of a non moving gg.
Old September 13th, 2005, 10:18 PM   #41
Michael Maier
We test light loss with f1.4 lens and it lose about 1 stop. That means the adapter lost less than 1 stop itself. Check the link below to compare between GG and Ariel image, thanks.
http://www.letus35.com/split.mpg
Quyen
Affordable Adapter
http://www.adapterplace.com
Quyen Le is offline   Reply With Quote
Old September 13th, 2005, 11:15 PM   #42
Ok, I got you. But if I read between the lines here, I would say that means,
"the Micro35 is sharper, but I will not get to a final conclusion till I test the Letus35 with a higher quality achromat (So the Letus ships with a lower quality achromat?) to see if the problem is in the achromat or in the adapter. But I prefer the Letus35 design."
By the way, the Letus also has a moving gg right?
by the way, are you testing any other adapters like the G35 or the Mighty Pico?
Old September 13th, 2005, 11:19 PM   #43
Originally Posted by Quyen Le
Michael Maier
Quyen
Thanks for the information.
Aerial means?
The gg side is actually brighter.
Old September 14th, 2005, 12:29 AM   #44
Old Boot
I've completely removed my post here! ! !
Now, Quyen, please explain the meaning of AERIAL?
Grazie
Old September 14th, 2005, 12:43 AM   #45
I am sorry that the GG and aerial text has been swapped. The Aerial side is actually GG side, and GG side is Aerial side,
Quyen
Affordable Adapter
