Canon XL & XH 24F, 25F, 30F capture in FCP / FCE - Page 4 at DVinfo.net
Final Cut Suite
Old January 4th, 2007, 09:08 PM   #46
Yes, sounds right. It's not a worry unless you need true 24P for either going to another tape format (which we were...going to the SONY deck to match other footage that was 24P) or doing a filmout.
Good luck.
Kevin Wild is offline   Reply With Quote
Old January 4th, 2007, 09:28 PM   #47
MPS Digital Studios
That link worked and I saw it. Thanks, Evan.
I talked to Apple, as well...they said unless you read about it, that's the problem--it's not labeled as 24F in FCP, so not too many non-XL H1 users know about it.
I'm going to try and get an XL H1 and capture the footage and analyze it, then go back to tape. I want to see if the clip is 24F or 29.97 fps.
heath
My Final Cut Pro X blog
Old January 5th, 2007, 01:34 AM   #48
Haven't had any time to really shoot/capture much to check this out but I just ran a quick capture of a few seconds of 24f footage through DVHSCap. Looking at the raw m2t file in MPEG Streamclip it reports:
Video Tracks:
2064 MPEG-2, 1440 × 1080, 16:9, 23.976 fps, 25.00 Mbps, lower field first
So I don't know exactly what to make of that - visually it appears to be true 24p footage, Stepping through frame by frame there's clearly no pulldown or interlacing visible in the file, and there are only 24 frames a second. The 'lower field first' is odd though - I tried a second clip and it came out saying 'upper field first', so I'm assuming it's an error in MPEG Streamclip and not an accurate representation of the video.
Evan Donn is offline   Reply With Quote
Old January 5th, 2007, 02:51 PM   #49
Originally Posted by Evan Donn
If canon is in fact recording a 24p signal within the standard 25Mbs HDV bandwidth then it would simply mean they are applying less compression per individual frame, as well as avoiding potential interlaced compression artifacts. However, this would also make the signal incompatible with any other HDV deck which expects to find a 60i stream on the tape - which seems to be exactly what's happening.
This is exactly what seems to be happening. The 24p signal is being recorded as 24 actual frames a second, using less compression, which does in fact account for the signal incompatibility with other HDV products. If the signal was being laid down in 60i, then we'd be able to use standard decks, much like with the DVX and XL2.
Barlow Elton has played around with the HD-SDI stuff more than any other H1 owner that I know of, and he says that 24F is laid down into 60i when going through HD-SDI, and that once recorded, you need to remove the pulldown to bring it back to 24p. Barlow also mentioned that FCP seems to be able to write 24F back out to tape. So if you capture 24F, edit and then need to go back to tape, that FCP will write out 24F back to tape correctly. I haven't tried this, as I haven't had a need to go back to tape yet! :)
As for DVHSCap, M2T's and MPEGStreamClip, there could be a glitch in either DVHSCap or StreamClip. Everything that I've captured with DVHSCap and bring into StreamClip that was shot 24F, shows upper field first every time. Maybe DVHSCap flagged something wrong. Maybe StreamClip read the flags wrong. Hard to say really.
At this point, it's pretty obvious to me, and most other H1 and A1 owners that 24F is laying down 24 distinct frames per second to tape. And at least to me, it's obvious that FCP is able to capture 24F using 5.1.2 with no problems, when using the Easy Setup for 1080p24.
Curtis Rhoads is offline   Reply With Quote
Old January 5th, 2007, 02:57 PM   #50
MPS Digital Studios
Curtis,
Right-click on a captured 24F clip and select Cinema Tools, then select analyze clip. Does it say 24p, 23.98 fps, 24F or 29.97 fps? If it's 29.97 fps, see if you can conform it to 23.98 fps or at least remove the pulldown, if there is one (and it's 29.97 fps). Try outputting it from FCP as a 23.98 fps QT Movie or QT Conversion.
Let us know what happens.
thanks,
heath
Old January 5th, 2007, 03:15 PM   #51
Ok, I grabbed one my clips from Halloween that was shot 24F and captured in FCP 5.1.2. Little background info... Using FCP Easy Setup 1080p24, clip was captured using Capture Now from inside FCP's capture window, and was captured to a file using the Apple HDV codec.
Cinema Tools reports the fps to be 23.98. I took a snapshot and posted it here:
http://www.realm.cc/upload/crhoads/Picture%201.png
Out of all the 24F captured footage that I've got on my drive right now, I checked about 7 different clips, and they all report 23.98 fps.
*Edit : Goofed on which codec is being used. Fixed.*
Old January 5th, 2007, 03:48 PM   #52
MPS Digital Studios
Curtis,
I wonder if making that an uncompressed HD file at 23.98 fps, if someone could take that to a post-house and put it on HDCAM or DVCPro HD?
heath
ps-That shot was scary-looking. nice!
Old January 5th, 2007, 07:18 PM   #53
Yes, this is what we went though. If shot, captured via Final Cut 24f and played out 24P via a Kona (only one we tested), it will be true 24P into a SONY deck.
If it's output directly from camera to the deck (via component or HD SDI), it will be read as 60i.
Old January 5th, 2007, 07:55 PM   #54
MPS Digital Studios
I'm trying to figure out why it's packaged in a 60i stream ONLY out HD SDI...
heath
Old January 8th, 2007, 09:27 PM   #55
Originally Posted by Heath McKnight
Curtis,
thanks,
heath
I've just finished filming with 24f in SD, not HD, on the Canon A1 and can't seem to capture without interlacing. Is it possible FCP is only reading 24f with HD footage? I'm going to try the above, but on the chance anyone can answer why I'm having this problem, gonna give a shout for help.
Lance Alton Troxel is offline   Reply With Quote
Old January 8th, 2007, 11:39 PM   #56
take a look at page 41 in the manual, it does a good visual job of illustrating what's going on with the various frame modes. Basically, a true 24p signal is only recorded in HDV mode. SD goes to tape in an interlaced signal with either a standard 2:3 pulldown or a 2:3:3:2 mode which I believe would be equivalent to panasonic's 24p advanced mode - so you'd want to use the second mode if you plan to edit the footage as 24p in FCP, there's a lot of good info about this here (scroll down pretty far for the Final Cut Pro settings):
http://www.kenstone.net/fcp_homepage..._nattress.html
Old January 10th, 2007, 11:34 AM   #57
Funny enough that's what I came up with, mostly by accident. Thanks for the tip in the manuel. Will def give it a read.
Old January 25th, 2007, 05:51 AM   #58
Canon 30F capture and editing in Final Cut Pro
OK....just got a new A1 and now I am trying to figure out the proper settings for capture and editing 30f in FCP.
I'm sure someone has already done this....so would you care to share your settings for capture and also your timeline settings for editing.
THANKS!!!
Canon HV20 | Sony FX1 | Canon XH-A1 | Sony XDCam EX1 | 8 Core Mac with FCP and lots of Hard Drives
Paul Kendal is offline   Reply With Quote
Old January 28th, 2007, 01:19 PM   #59
I just tried 30F for the first time. Captured fine on 1080i60 easy setup on the sony firewire setting. FCP 5.1.2, capturing from camera. 1080i60 timeline. Looks beautiful and looks progressive. Frame grabs have no scan lines and no strobing. Don't understand how it works, but it's cool.
Chuck Fadely is offline   Reply With Quote
Old January 28th, 2007, 02:22 PM   #60
I thought 30f captures progressively like 1080p30?
Jonathan Nelson is offline   Reply
