FCP 7 & Sony XDCAM EX Log and Transfer? at DVinfo.net
Final Cut Suite
Old August 30th, 2009, 09:49 PM   #1
I have been trying to ingest EX3 clips from a BPAV folder after installing the Sony XDCAM EX Log and Transfer plugin (ver. 1.0..) and keep receiving the following error message:
"359_0096_01" contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media."
Problem solved ... operator misunderstanding.
It appears that the BPAV folder must be located in a secondary folder of its own. Once that was accomplished, the ingestion process was very quick indeed, much speedier than ingestion via the Transfer utility.
Ron Wilk is offline   Reply With Quote
Old August 31st, 2009, 07:32 AM   #2
Are you using FCP7? I've found ingestion is faster now with the new Log & Transfer, whereas XDCT used to be faster.
www.packcreekproductions.com
EX3, Mac Pro, FCP
Mike Chandler is offline   Reply With Quote
Old August 31st, 2009, 02:00 PM   #3
Agreed, Log and Transfer is many times faster than XDCT with the new FCP 7.
