Way to batch convert from DV-AVI to MOV?
While processing my footage for my own purposes, I am also submitting universally useful clips to a stock footage consignment house. The clips are already sliced into short files on my hard disk with logical filenames, so it would be nice to send them off as files rather than putting them back on tapes and having to write clip logs. The company would also thank me for saving them the work of capturing them and figuring out what each one is. (Unfortunately I think they only thank me, not raise my commission...)
But while my files are AVI with Microsoft-DV codec (I think that's right - it's whatever Premiere Pro produces), the stock footage company uses all Macs and wants the clips as Quicktime (and would be really happy if I could even provide both NTSC and PAL versions). I have hundreds of files - pulling them into my PPro CS3 one by one and exporting them to MOV (typing or copy/pasting each filename, because the default name of an export is that of the timeline, not a single asset sitting on it) would be a huge job. Is there a good tool out there that can do such a conversion in batch on selected files, or all the files in a folder, or something? |
Hi Karen
This program is probably what you are looking for, itīs called MPEG Streamclip and itīs free. Squared 5 - MPEG Streamclip video converter for Mac and Windows It can batch convert to Quicktime Cheers Hans |
If that doesn't work, you can batch convert in After Effects, or now the new Adobe Media Encoder. We convert DV AVI to DV MOV and vice versa, all the time this way.
Procoder is definitely not necessary for that type of DV work. After Effects or Media Encoder CS4 will both automatically pass the filename thru to the new MOV file. We use AE to convert 44.1Khz WAV files to 48Khz with thousands of files, so it works fine for that type of project.
