Mini35 zoom with DVX at DVinfo.net
Alternative Imaging Methods
Old September 6th, 2006, 08:20 PM   #1
For all you Mini35 users that have used it with the DVX100, 100A, 100B... What was your zoom setting to be in full frame of the ground glass?
Sean Michael is offline   Reply With Quote
Old September 7th, 2006, 12:14 PM   #2
Always zoom all the way in for correct field of view.
http://www.IndieRentals.com
RED Rentals, Camera, Grip, Lighting, Sound, Post and More.
http://www.madmojo.com
Production blog.
Eric MacIver is offline   Reply With Quote
Old September 7th, 2006, 12:19 PM   #3
you zoom all the way to z99? You can't pull it back to like Z90?
Old September 9th, 2006, 11:43 AM   #4
If you have a monitor w/ underscan, you can see how far you can pull back without seeing the corners of the GG. The image should still be fine in all respects, but the field of view of the lens will be different than normal (ie a 25mm lens may act like a 22mm or so, in terms of FOV only).
Production blog.
