lighting for interviews?
Hi Guys
I have a job coming up which involves filming some 2 minute interviews with company directors. Initially i envisaged the interviewees in a blackout room and just lighting the person up, is this feasible to set up in a meeting room? Also, what lighting kits would I need or recommend? I have seen many ranging from £90 to £1200!! I dont think my budget can go past £500 Hope you can help |
Re: lighting for interviews?
It sounds like you've not done this before? If so, then you might want to knock the blackout on the head and go with the most simple and easy set up. Shooting these kind of jobs, at least in my experience, is usually very quick in turnaround, with little to no set up time. Blackouts can be tricky to get right, especially in a small room.
How about hiring a couple of light kits for now? |
A black background drape would be the way to go. It's difficult to get a black in your standard white walled office.
Thanks Adrian/Brian
You're right, I havent ventured into video lighting before although I supply a DJ/singer and uplighting service for the region Home - welcome to Pzazz Parties I often wondered if up lighters (american DK LED megapanels as i have 24 of them) could be utilised but the white is a mixture of RGB so not wonderful. Never really thought of hiring which could be an option. Am I to think that when the Pro's do this, they do it in a controlled environment in their studio? Thanks |
3 Attachment(s)
The reality of how you put together an interview setup is nothing like what you might expect it to be.
The setup you see in the attached crappy cellphone photos ( IMAG0164.jpg & IMAG0165.jpg) took about 1.5hrs to setup then another thirty min to tweak to the style sheet sent by the network. We were in a briefing room of a police station. This room had emergency lights we couldn't turn off so they had to be covered. This one was more complicated because it was being shot in multiple locations by different crews but they wanted it all to match. Way overkill for most needs but an example of how much work can go into some of these setup. For a much simpler and more common setup using a conference room check out FV Interview.jpg. This is a setup for a corporate video. We used the length of the room to get some depth in the shot and put a table and the other things you see in the background there to add some interest. It took 5 lights for this setup (including the lamp on the table). Lighting setup for the conference room shoot: 2 softlights for key/fill 1 hard light for light slash on wall (HMI with CTO gel) 1 light for highlight on plant 1 practical (lamp) Not a light but important: 1 piece of black fabric on the ceiling to choke spill from the lights in the background. Some of the basic ideas to incorporate in your setups where you can is to get the subjects away from walls. Distance between your subjects and the background is your friend. Put things in the background to add visual interest and/or context for the interview. Lighting matters. There are tons of writings on the subject. Read as much of it as you can get your hands on. Tricks for your kit - Get some white and black foam board from your local craft store or walmart. Have a couple of moving blankets and a background stand in your kit. Use them as positive and negative fill to make your lighting more interesting. This stuff can be had very cheaply and are very powerful tools to control the environment and make your interviews look professional. Its not always about adding light. Sometimes you need to take it away to get the shape you want. Have fun and know its a journey. :) |
You may find this book useful:
As for lighting kit a basic set-up involves three lights and this can be a set of tungsten redheads or some led lights all the way up to some fresnels or even dedo lights. I would avoid RGB lights as they will give colour casts but they could be useful for lighting backgrounds and black backdrop material is a godsend. I am just across the pennines in Co Durham and have loads of kit if you wish to loan some to try out rather than buy for one job. |
